after updating to openhab2.4 on my raspberry, the homegear-binding throws this error:
2018-12-29 09:00:17.877 [WARN ] [ematic.handler.HomematicThingHandler] - Can’t convert type QuantityType with value ‘4.5 °C’ to FLOAT value with DecimalTypeConverter for ‘NEQ0670874:1#MANU_MODE’, please check the item type and the commands in your scripts
2018-12-29 09:00:17.888 [WARN ] [ematic.handler.HomematicThingHandler] - Can’t convert type QuantityType with value ‘4.5 °C’ to FLOAT value with DecimalTypeConverter for ‘NEQ1252471:1#MANU_MODE’, please check the item type and the commands in your scripts
I want to set my MAX-thermostat to status OFF( off == 4,5 with MAX) within this rule:
rule "Dachfenster auf"
Item Fensterkontakt1_1_State changed to OPEN
// logInfo("Heizung Dachgeschoss","Dachfenster geöffnet")
Heizkoerperthermostat1_1_ManuMode.sendCommand(4.5)
Heizkoerperthermostat2_1_ManuMode.sendCommand(4.5)
// logInfo("Heizung Dachgeschoss","Heizung Dachgeschoss ausgeschaltet")
I have tried several formats like a single 5 “4,5” “4.5” but nothings works.
Any hints to shutdown the thermostats?
Greets
Andy
