rule "Batterie leer"
Item gBattery changed to ON
val lastitem = gBattery.members.filter[i | i.lastUpdate !== null].sortBy[lastUpdate].last
sendTelegram("main",lastitem.label+": Bitte Batterie wechseln !")
with
Group:Switch:OR(ON, OFF) gBattery
comes to the following error message, Why?
[ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Batterie leer': java.lang.Double cannot be cast to java.lang.String
Add some logInfo to find out what line the rule breaks
logInfo("RULE","BREAK 1")
logInfo("RULE","BREAK 2")
val lastItem = Windows.members.filter[ w | w.lastUpdate !== null ].sortBy[ lastUpdate ].last
val String nameOfItem = lastItem.name
The only difference I can see are the spaces after [ and before ] and lastItem.name instead of .label. But not sure as I don’t know the Telegram-Command itself. Hope this helps
Thought with putting the values “everyminute” into persistence should result in no "null"s. At least I have to have more time to check this. Meanwhile any hints are welcome …
