I just installed openHAB on a new computer (from openHABian to Docker) and transferred the settings for the directories userdata and conf.
Now I get the following error for my Homematic CCU2 shortly after going online:
==> /srv/docker/openhab/userdata/logs/openhab.log <==
2019-01-12 21:15:59.689 [WARN ] [ommunicator.AbstractHomematicGateway] - Connection lost on gateway 'MEQ0228853', cause: "No Pong received!"
The callback address is non-docker address of your server.
Docker creates internal interfaces with their own IP-addresses. So in my example the server openhab runs on has the ip-address 10.0.2.71, the openhab docker container has something in the 172.xxx.xxx.xxx range.
Usually this should be an address starting with 10.xxx.xxx.xxx or 192.168.xxx.xxx
I can confirm that entering the “Callback Network Address” (entered IP address of my server) solved also the “No pong received!” issue on my Synology Diskstation.
