LukaNoah
(Heiko Hegewald)
March 3, 2019, 5:26pm
1
Hello, how can I convert the thread :: sleep into a timer in the following lambda?
val Functions$Function4<SwitchItem , Integer, Integer, Integer, Boolean> repeater= [
m_switch,
m_delay,
m_repeat,
m_sleep |
var Timer DelayTimer=null
DelayTimer = createTimer(now.plusMillis(m_delay)) [ |
var count = m_repeat + 1
var i=0
while ((i=i+1) < count )
logInfo ("RULES", "AUTO-Licht -- " + m_switch.name + ": Wiederholung " + i + " - Command " + m_switch.state)
if (m_switch.state == ON)
m_switch.sendCommand(ON)
else
m_switch.sendCommand(OFF)
Thread::sleep(m_sleep)
logInfo("RULES", "AUTO-Licht -- "+ m_switch.name + " ist " + m_switch.state.toString)
DelayTimer.cancel
DelayTimer=null
true
The lambda should repeat a command to RFXCOM outlets. The number of repetitions (m_repeat), the delay at the beginning (m_delay) and the delay between the commands (m_sleep) are parameters of the function.
thanks
Heiko
pacive
(Anders Alfredsson)
March 3, 2019, 5:57pm
2
Haven’t tested it, but I believe something like this should work:
m_switch,
m_delay,
m_repeat,
m_sleep |
var count = 1
logInfo ("RULES", "AUTO-Licht -- " + m_switch.name + ": Wiederholung " + count + " - Command " + m_switch.state)
else
if (count < m_repeat) {
DelayTimer.rescedule(now.plusMillis(m_sleep))
} else {
DelayTimer.cancel
DelayTimer=null
true
Edit: Not entirely sure if all variables in a lambda gets passed to the timer. After the timer is created, the lambda returns, and the variables might disappear at that point.
LukaNoah
(Heiko Hegewald)
March 3, 2019, 6:51pm
3
thanks, but it’s don’t work:
I corrected the typos in your script.
thanks
LukaNoah
(Heiko Hegewald)
March 3, 2019, 7:00pm
4
Yes, I’ve got it.
m_switch,
m_delay,
m_repeat,
m_sleep |
var count = 1
else
DelayTimer.reschedule(now.plusMillis(m_sleep))
count = count + 1
else
DelayTimer.cancel
DelayTimer=null
true
That’s how it should work, I’ll watch.
Thank you for the approach.
