I’m new with the modbus bindings and I try to connect my openhab to TWO server devices using the modbus bindings.
the first device is a SMA inverter. IP adress: 192.168.0.208
the second device is a Stiebel Eltron heatpump. IP adress : 192.168.0.207
my config files is:
Bridge modbus:tcp:inverter1 [ host=“192.168.0.208”, port=502, id=3, connectMaxTries=3] {
// SMA Inverter Device Type
Bridge poller DevType [ start=30053, length=4, refresh=60000, type=“input” ] {
Thing data type @ “PV” [ readStart=“30053”, readValueType=“uint32” ]
}// SMA Inverter Status
Bridge poller SMA_Status [ start=30201, length=36, refresh=60000, type=“input” ] {
Thing data status @ “PV”[ readStart=“30201”, readValueType=“int32” ]
Thing data Grid_Contactor @ “PV”[ readStart=“30217”, readValueType=“int32” ]
Thing data Max_Power @ “PV”[ readStart=“30231”, readValueType=“int32” ]
Thing data Set_Max_Power @ “PV”[ readStart=“30233”, readValueType=“int32” ]
}// SMA Inverter Yield
Bridge poller Yield [ start=30517, length=16, refresh=60000, type=“input” ] {
Thing data Day_Yield @ “PV”[ readStart=“30517”, readValueType=“int64”, readTransform=“JS(divide1000.js)” ]
Thing data Total_Yield @ “PV”[ readStart=“30529”, readValueType=“int32”, readTransform=“JS(divide1000.js)” ]
}// SMA Inverter Power Section West & Total
Bridge poller power_a [ start=30769, length=20, refresh=5000, type=“input” ] {
Thing data current_input @ “PV”[ readStart=“30769”, readValueType=“int32”, readTransform=“JS(smalimit1000.js)” ]
Thing data voltage_input @ “PV”[ readStart=“30771”, readValueType=“int32”, readTransform=“JS(smalimit100.js)” ]
Thing data power_west @ “PV”[ readStart=“30773”, readValueType=“int32”, readTransform=“JS(smalimit.js)” ]
Thing data active_power @ “PV”[ readStart=“30775”, readValueType=“int32”, readTransform=“JS(smalimit.js)” ]
Thing data power_L1 @ “PV”[ readStart=“30777”, readValueType=“int32”, readTransform=“JS(smalimit.js)” ]
Thing data power_L2 @ “PV”[ readStart=“30779”, readValueType=“int32”, readTransform=“JS(smalimit.js)” ]
Thing data power_L3 @ “PV”[ readStart=“30781”, readValueType=“int32”, readTransform=“JS(smalimit.js)” ]
Thing data volt_G1 @ “PV”[ readStart=“30783”, readValueType=“uint32”, readTransform=“JS(divide100.js)” ]
Thing data volt_G2 @ “PV”[ readStart=“30785”, readValueType=“uint32”, readTransform=“JS(divide100.js)” ]
Thing data volt_G3 @ “PV”[ readStart=“30787”, readValueType=“uint32”, readTransform=“JS(divide100.js)” ]
}// SMA Inverter Power Section East
Bridge poller power_b [ start=30957, length=8, refresh=5000, type=“input” ] {
Thing data currentB_input @ “PV”[ readStart=“30957”, readValueType=“int32”, readTransform=“JS(smalimit1000.js)” ]
Thing data voltageB_input @ “PV”[ readStart=“30959”, readValueType=“int32”, readTransform=“JS(smalimit100.js)” ]
Thing data power_east @ “PV”[ readStart=“30961”, readValueType=“int32”, readTransform=“JS(smalimit.js)” ]
}// SMA Inverter Operation
Bridge poller SMA_Status_Operate [ start=40029, length=4, refresh=5000, type=“holding” ] {
Thing data operatestatus @ “PV”[ readStart=“40029”, readValueType=“uint32” ]
}Bridge modbus:tcp:heatpump [ host=“192.168.0.207”, port=502, id=1] {
Thing modbus:heatpump:stiebelEltron “StiebelEltron” (modbus:tcp:modbusheatpump)
Only the heatpump is create, no inverter. Individually, inverter and heatpump config were OK but when I but them together, it’s not working anymore.
Any idea why it’s wrong?
