I have defined the static ttyUSB_ZigBee for my ZigBee dongle by udev.
How can I configure this as the serial port at openHAB?
PaperUI shows just the dynamic types ttyUSB0/1/2 as config options for the thing. The other two dongles are CUL. These static serial ports I configured by homegear conf files (Max and Homematic).
Cant‘ find any hint in the community regarding the ZigBee dongle (Qivicon).
I’m using OpenHABian now (which is OpenHAB preset on the Raspbian OS).
In
/etc/default/openhab2
there is a line (or should be) like
EXTRA_JAVA_OPTS=“-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0”
Just enumerate your serial ports, adding those that you create by usb dev rules.
In my experience it is better to prefix the name with ‘tty’.
So /dev/ttyZigBee would be a good candidate.
