[Solved] How to define a serial port on raspberry for openhab2 for my razberry zwave binding?
Finally online
As I understand from domoticanoob.nl the razberry uses the same port on the raspberry pi 3 as bluetooth. So if you are not really need bluetooth :
sudo echo “dtoverlay=pi3-disable-bt” >> /boot/config.txt
sudo reboot now
after reboot /dev/ttyAMA0 is available again.
Why it does work with Z-way I completely don’t understand. But i’m online now!!!
Hi Peter,
i didn’t find the folder: runtime/karaf
can you tell me how can i to change the setenv file.?
just start to use openhabian and you get the option to configure razberry via a menu. btw.. there is not need to change setenv in /usr/share/openhab2/runtime/bin anymore… just configure the port via the menu in openhabian or do it manually via sudo nano /etc/default/openhab2
e.q. EXTRA_JAVA_OPTS=" -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0:/dev/ttyUSB0"
In
/etc/udev/rules.d/
everyone may define their own USB device naming rules.
Here it is possible to create device names such as but not limited to
/dev/razberry
/dev/optoma
/dev/jeelink
/dev/cul868
etc.
instead of cryptic ones like
/dev/AMA0
/dev/ACM0
/dev/USB0
/dev/USB1
The later is the use case for this rules:
Assumed you have 2 USB->RS232 devices connected to your Raspberry Pi, both using the same adapter chip like the FTDI, they will be numbered /dev/USB0 and /dev/USB1. Now this is dangerous. If you replug them in an arbitray order into the usb sockets, the numbers may change. To prevent this the udev rules were invented.
You may even fix permissions (!), owner and group in rules, and they are automatically applied every time you plug in your device, no manual interaction needed and it will survive a reboot.
See for example:
I spent hours on this, only to find that I was setting the variable EXTRA_JAVA_ARGS in /etc/default/openhab2 while the actual variable that /usr/share/openhab2/runtime/bin/shell uses is EXTRA_JAVA_OPTS. The very small difference in variable name is so easy to overlook that it took me a very long time to notice it.
Now that updated in /etc/default/openhab2 with the line I can finally get OH2 to start correctly even when Ubuntu decides to renumber my /dev/ttyUSB ports randomly.
EXTRA_JAVA_OPTS=-Dgnu.io.rxtx.SerialPorts=/dev/insteon:/dev/zwave:/dev/prolific
I hope this helps someone.
I had a similar problem, I always received an error that my Razberry serial device was not identified after upgrading from Openhab 2.0 to 2.1. The error console showed “OFFLINE (COMMUNICATION_ERROR): zwave.thingstate.serial_notfound”.
It turns out that the serial port needs to be specifically activated for Java. I had to manually edit /etc/default/openhab2 and add the line “EXTRA_JAVA_OPTS=”-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0". Then it worked.
Hello guys n girls,
I’m having a nightmare trying to get my Z-wave controller and AEON 5-way sensor to work in OH2.2 I seem to be going round in circles when I try to search for the solution on the forum…many talk about similar issues but there does not seem to be an easy step by step guide to setting up the Z-wave USB stick on my Raspberry Pi. I just tried the above steps and rebooted my Pi to get the following errors in the log:
2018-08-18 22:28:57.795 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:5ad5c18c' changed from UNINITIALIZED to INITIALIZING
2018-08-18 22:28:57.930 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2018-08-18 22:28:57.937 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:5ad5c18c' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-18 22:28:57.984 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-08-18 22:28:58.011 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-08-18 22:28:58.056 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-08-18 22:28:58.060 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
Also to clarify in my OH service Option I have the following line added:
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
Any suggestions…and please help with a view that I’m a Linux noob :slight_smile:
Thanx Chris.
You’re not getting much in your log, so turn on debugging. In the Karaf console, run:
log:set DEBUG org.openhab.binding.zwave
Then restart OH and see what the log tells you. Remember to set the logging back to INFO or WARN when you are done troubleshooting! Just run this again, but replace DEBUG with the new logging level.
Thanx for the fast response 5iver!
I did say that I’m a Linux Noob…so how to get in to karaf…I searched and found the topic that should have given me the answer but alas like so many topics on here they are out of dated and lead the Linux novice like me around in circles!!
https://community.openhab.org/t/karaf-console/7982/15
In Putty I ran command: “ssh karaf@localhost -p 8101” but couldn’t pass the password prompt. Then I tried “sudo ssh karaf@localhost -p 8101” and it asked me for my openhabian password:
[09:28:34] openhabian@openHABianPi:~$ sudo ssh karaf@localhost -p 8101
[sudo] password for openhabian:
The authenticity of host '[localhost]:8101 ([::1]:8101)' can't be established.
RSA key fingerprint is SHA256:NktZswipTeJCra4vbkdWk7oFQ1XGOGwXXs9Xs8Z50P0.
Are you sure you want to continue connecting (yes/no)? y
Please type 'yes' or 'no': yes
Warning: Permanently added '[localhost]:8101' (RSA) to the list of known hosts.
Password authentication
Password:
Here I exited Putty so as (hopefully) not proceed any further with something that I don’t know.
Can I extend the logs just using Putty and ssh?
Thanx and BR
Chris
That’s an old post… the docs are more current…
There may be some nuances using openHABian…
Here are some details on logging. You could also just edit a file, rather than use Karaf…
I’m using openhabian and this is how I access the Karaf console:
SSH in via Putty then type in sudo openhab-cli console (you may or may not need to use sudo)
User: openhab
Password: habopen (or whatever your password is)
Then as mentioned above
Thank you people for the replies and assistance, I made some headway but still can not get data out of the Aeon DSB05 4 way sensor …yet. But i have managed to get the Z-Wave 5 USB stick to work and now get the following logs from a system restart:
2018-08-26 00:07:58.736 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:5ad5c18c' changed from UNINITIALIZED to INITIALIZING
2018-08-26 00:07:58.802 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:5ad5c18c' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-08-26 00:07:58.804 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2018-08-26 00:07:58.828 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-08-26 00:07:58.841 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-08-26 00:07:58.864 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-08-26 00:07:58.866 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-08-26 00:08:01.299 [ome.event.ItemCommandEvent] - Item 'OHFriendlyUptime' received command 0d 3h 3m
2018-08-26 00:08:01.307 [vent.ItemStateChangedEvent] - OHFriendlyUptime changed from 0d 3h 1m to 0d 3h 3m
2018-08-26 00:08:01.899 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 10 to 1
2018-08-26 00:08:01.901 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 10 to 1
2018-08-26 00:08:01.943 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 1 to 2
2018-08-26 00:08:01.944 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 1 to 2
2018-08-26 00:08:01.952 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 2 to 3
2018-08-26 00:08:01.954 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 2 to 3
2018-08-26 00:08:01.976 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 3 to 4
2018-08-26 00:08:01.981 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 3 to 4
2018-08-26 00:08:01.987 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 4 to 5
2018-08-26 00:08:01.990 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 4 to 5
2018-08-26 00:08:01.996 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 5 to 6
2018-08-26 00:08:02.092 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 5 to 6
2018-08-26 00:08:02.097 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-08-26 00:08:02.099 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-08-26 00:08:02.100 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-08-26 00:08:02.101 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-08-26 00:08:02.103 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 1
2018-08-26 00:08:02.105 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-08-26 00:08:02.115 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 6 to 7
2018-08-26 00:08:02.118 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 6 to 7
2018-08-26 00:08:02.721 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:5ad5c18c' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-08-26 00:08:02.730 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 7 to 8
2018-08-26 00:08:02.733 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 7 to 8
2018-08-26 00:08:02.745 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 8 to 9
2018-08-26 00:08:02.750 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 8 to 9
2018-08-26 00:08:02.774 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_ack changed from 9 to 10
2018-08-26 00:08:02.776 [vent.ItemStateChangedEvent] - zwave_serial_zstick_5ad5c18c_serial_sof changed from 9 to 10
But I cant figure out how to get the sensor data to output. I have the NULL data on my Sitemap. I think it is something to do with adding the sensor channels to OH but I have not found any solution yet. If i go in to Paper UI/Services/IO and the “Configure” option ther is at the top right side an option “Items to expose to apps such as IFTTT” and in the drop down menu that appears i can find the AEON sensor channels such as Hallway_Humidity, Hallway_Luminence, Hallway_Motion and Hallway_Temperture…so from this I deduce that the sensor has been “seen” by OH.
My Default.Items entry is like this:
// 5-Way Multi Sensor (temp, humid, light, motion, batt)
Number   Hallway_Temperature "Hallway Temperature [%.1f °C]"    <temperature>    (FF_Hallway,GF_Entryway,TemperatureSensor)    {zwave="2:0:command=sensor_multilevel,sensor_type=1,sensor_scale=0"}
Number   Hallway_Humidity    "Hallway Humidity    [%.0f %%]"    <humidity>       (FF_Hallway,GF_Entryway,TemperatureSensor)    {zwave="2:0:command=sensor_multilevel,sensor_type=5"}
Number   Hallway_Luminance   "Hallway Luminance   [%.0f Lux]"   <light-off>      (FF_Hallway,GF_Entryway,TemperatureSensor)    {zwave="2:0:command=sensor_multilevel,sensor_type=3"}
Contact  Hallway_Motion      "Hallway Motion [%s]"              <motion>         (FF_Hallway,GF_Entryway,TemperatureSensor)    {zwave="2:0:command=sensor_binary,respond_to_basic=true"}
Number   sensor_1_battery    "Battery [%s %%]"                  <battery>        (FF_Hallway,GF_Entryway,TemperatureSensor)    {zwave="2:0:command=battery"}
and my Default.sitemap is like this:
            Text item=Hallway_Temperature label="Hallway Temperature"    icon="temperature"
            Text item=Hallway_Humidity    label="Hallway Humidity"       icon="humidity"
            Text item=Hallway_Luminance   label="Hallway Luminance"      icon="light-off"
            Switch item=Hallway_Motion    label="Hallway Motion"         icon="motion"
            Text item=sensor_1_battery    label="Battery Level"          icon="battery"
If I go in to Paper UI and the Control then select my Z-wave item all I see there is:
Start Frames 10
Frames Acknowledged 10
Frames Rejected -NAN
Frames Cancelled -NAN
OOF Bytes Received -NAN
The AEON DSB05 has been updated to the latest firmware available from the AEON website.
Any suggestions?
You have you items defined for a 1.x version of the binding. They should look like something like this for 2.x (only the channel part is relevant)…
Dimmer    US_DiningRoom_Dimmer    "Dining Room [%d%%]"    <slider>   (gUS_DiningRoom,gUS_DiningRoom_Action,gLight)    ["Lighting"]    {channel="zwave:device:55555:node36:switch_dimmer"}
In PaperUI> Configuation> Things> select the Thing> there is a clipboard icon by each channel you can use to copy the channel info and paste into an items file.
learning, learning, 1…2…3…
OK with a bit more searching I found that AFTER we set up the controller that we have to ADD the sensor! I had done that but not in the correct manner.
Steps are:
  1. Set up Z-Wave USB controller.
  2. Then go to OH UI and INBOX then click add items.
    3)Then press the inclusion button on the Z-Wave USB stick followed by the Inclusion button on the sensor.
  3. Wait for the sensor to be interrogated by OH…I’m still waiting for that bit.
I will report back with further learnings until its working.
Well fter all night the Sensor Aeon DSB05 is still shown as an “Unknown device”. This morning I went to the Inbox and pressed “Search” for items, then presssed and released the Z-Wave v5 USB stick inclusion button followed by press and released the Sensor inclusion button…the Log is below showing the first line as displayed all last night and then the above attempt at discovering the Sensor. Does anyone have any ideas about what I need to do to complete the sensor discovery? Do I need to edit and of the .xml Zwave files or any other system files to get the sensor to be recognised?
Thanx Chris.
Logs Part 1 (Filtered for Zwave):
2018-08-27 07:31:50.525 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling deferred until initialisation complete
2018-08-27 08:01:50.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling...
2018-08-27 08:01:50.523 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling deferred until initialisation complete
2018-08-27 08:31:50.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling...
2018-08-27 08:31:50.526 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling deferred until initialisation complete
2018-08-27 09:01:50.517 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling...
2018-08-27 09:01:50.521 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Polling deferred until initialisation complete
2018-08-27 09:12:46.261 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2018-08-27 09:12:46.266 [DEBUG] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2018-08-27 09:12:46.270 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Starting ZWave inclusion scan for zwave:serial_zstick:e029b827
2018-08-27 09:12:46.274 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery completed
2018-08-27 09:12:46.278 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_psr04_00_000
2018-08-27 09:12:46.283 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw097_00_000
2018-08-27 09:12:46.288 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw097_00_000
2018-08-27 09:12:46.293 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw097_00_000
2018-08-27 09:12:46.299 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_zw37_00_000
2018-08-27 09:12:46.304 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_sir321_00_000
2018-08-27 09:12:46.309 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_sir321_00_000
2018-08-27 09:12:46.315 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zmekfobs_00_000
2018-08-27 09:12:46.321 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zmekfobs_00_000
2018-08-27 09:12:46.325 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zmekfobs_00_000
2018-08-27 09:12:46.331 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt2755_00_000
2018-08-27 09:12:46.335 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs223_00_000
2018-08-27 09:12:46.337 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs223_00_000
2018-08-27 09:12:46.341 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs223_00_000
2018-08-27 09:12:46.344 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_doorsensorin_00_000
2018-08-27 09:12:46.346 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ca3750_00_000
2018-08-27 09:12:46.350 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fggc001_00_000
2018-08-27 09:12:46.353 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fggc001_00_000
2018-08-27 09:12:46.356 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fggc001_00_000
2018-08-27 09:12:46.359 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme05431_00_000
2018-08-27 09:12:46.362 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_sp103_00_000
2018-08-27 09:12:46.365 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_so05_00_000
2018-08-27 09:12:46.368 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:econet_ebv105_00_000
2018-08-27 09:12:46.370 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_im20_00_000
2018-08-27 09:12:46.372 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_im20_00_000
2018-08-27 09:12:46.374 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_508519_00_000
2018-08-27 09:12:46.377 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:widom_ubs_01_000
2018-08-27 09:12:46.379 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dlink_dchz510_00_000
2018-08-27 09:12:46.381 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt02647_00_000
2018-08-27 09:12:46.383 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_doorsensor_00_000
2018-08-27 09:12:46.386 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_doorsensor_00_000
2018-08-27 09:12:46.388 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.391 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.394 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.397 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.400 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.403 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.406 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.409 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.412 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.415 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_004
2018-08-27 09:12:46.418 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_wcd2_00_000
2018-08-27 09:12:46.422 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_kfob_00_000
2018-08-27 09:12:46.425 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_kfob_00_000
2018-08-27 09:12:46.428 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an163_00_000
2018-08-27 09:12:46.431 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_14318_00_000
2018-08-27 09:12:46.434 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100plus_00_000
2018-08-27 09:12:46.437 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_powerswitch_00_000
2018-08-27 09:12:46.440 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhid_00_000
2018-08-27 09:12:46.443 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:nodon_asp31_00_000
2018-08-27 09:12:46.446 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_nzw96_00_000
2018-08-27 09:12:46.449 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tsm02_00_000
2018-08-27 09:12:46.452 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zd2102_00_000
2018-08-27 09:12:46.455 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zd2102_00_000
2018-08-27 09:12:46.458 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zd2102_00_000
2018-08-27 09:12:46.461 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_wallcs_00_000
2018-08-27 09:12:46.464 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_ses302_00_000
2018-08-27 09:12:46.467 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhwd_00_000
2018-08-27 09:12:46.470 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pat02c_00_000
2018-08-27 09:12:46.473 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3103_00_000
2018-08-27 09:12:46.476 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:econet_ev100_00_000
2018-08-27 09:12:46.479 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zipato_bulb2rgbw_00_000
2018-08-27 09:12:46.482 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:polycontrol_btze_01_002
2018-08-27 09:12:46.485 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:polycontrol_btze_01_002
2018-08-27 09:12:46.488 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ufairy_grm202n2_00_000
2018-08-27 09:12:46.491 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_c17zw_00_000
2018-08-27 09:12:46.494 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsa03202_00_000
2018-08-27 09:12:46.497 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsa03202_00_000
2018-08-27 09:12:46.500 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zl7432_00_000
2018-08-27 09:12:46.503 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:brk_zsmoke_00_000
2018-08-27 09:12:46.506 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc27_00_000
2018-08-27 09:12:46.509 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_hrvccm_00_000
2018-08-27 09:12:46.512 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_hrvccm_00_000
2018-08-27 09:12:46.515 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgsd002_00_000
2018-08-27 09:12:46.518 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_dhszwdmiw01_00_000
2018-08-27 09:12:46.521 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh8fc4_00_000
2018-08-27 09:12:46.524 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveproducts_wd100_00_000
2018-08-27 09:12:46.527 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45604_00_000
2018-08-27 09:12:46.530 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45604_00_000
2018-08-27 09:12:46.533 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45604_00_000
2018-08-27 09:12:46.536 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.539 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.542 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
Log Part 2:
2018-08-27 09:12:46.545 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.549 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.552 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.555 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.558 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct30_00_000
2018-08-27 09:12:46.561 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz88_00_000
2018-08-27 09:12:46.563 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz88_00_000
2018-08-27 09:12:46.565 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cbcc_swzcs1_00_000
2018-08-27 09:12:46.567 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw129_00_000
2018-08-27 09:12:46.570 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw129_00_000
2018-08-27 09:12:46.572 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw129_00_000
2018-08-27 09:12:46.574 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_064394_00_000
2018-08-27 09:12:46.576 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc08_00_000
2018-08-27 09:12:46.578 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct110_00_000
2018-08-27 09:12:46.580 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct110_00_000
2018-08-27 09:12:46.582 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_scsc17_00_000
2018-08-27 09:12:46.585 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_hkzwfld01_00_000
2018-08-27 09:12:46.587 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_hac01_00_000
2018-08-27 09:12:46.589 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_builtindimmer_00_000
2018-08-27 09:12:46.591 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrm222_24_024
2018-08-27 09:12:46.593 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrm222_24_024
2018-08-27 09:12:46.595 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrm222_24_024
2018-08-27 09:12:46.597 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_hkzwms01_00_000
2018-08-27 09:12:46.600 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_azemt500bb32ma_00_000
2018-08-27 09:12:46.602 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_scn04_00_000
2018-08-27 09:12:46.604 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wt00z1_00_000
2018-08-27 09:12:46.606 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw121_00_000
2018-08-27 09:12:46.608 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw121_00_000
2018-08-27 09:12:46.610 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:forest_forestshuttlesl_00_000
2018-08-27 09:12:46.612 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dz15s_00_000
2018-08-27 09:12:46.614 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs412_00_000
2018-08-27 09:12:46.617 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fireangle_zst630_00_000
2018-08-27 09:12:46.619 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_psm02_00_000
2018-08-27 09:12:46.621 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw117_00_000
2018-08-27 09:12:46.623 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw117_00_000
2018-08-27 09:12:46.626 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw117_00_000
2018-08-27 09:12:46.628 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz69_00_000
2018-08-27 09:12:46.631 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz69_00_000
2018-08-27 09:12:46.633 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:steinel_l810ledihf_00_000
2018-08-27 09:12:46.635 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgwp102_02_001
2018-08-27 09:12:46.638 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge28169_00_000
2018-08-27 09:12:46.640 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:steinel_xledhome2_00_000
2018-08-27 09:12:46.642 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs312_00_000
2018-08-27 09:12:46.644 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs312_00_000
2018-08-27 09:12:46.646 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge28167zw3104_00_000
2018-08-27 09:12:46.649 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:northq_nq9121_03_000
2018-08-27 09:12:46.651 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:nodon_softremote_00_000
2018-08-27 09:12:46.654 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:isurpass_dl9101v_00_000
2018-08-27 09:12:46.656 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eurotronic_spirit_00_000
2018-08-27 09:12:46.658 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eurotronic_spirit_00_000
2018-08-27 09:12:46.660 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_gb00z_00_000
2018-08-27 09:12:46.662 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:jintaobao_curtainmotor_00_000
2018-08-27 09:12:46.664 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen15_00_000
2018-08-27 09:12:46.667 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_gr308_00_000
2018-08-27 09:12:46.669 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgr221_00_000
2018-08-27 09:12:46.671 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgr221_00_000
2018-08-27 09:12:46.673 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgr221_00_000
2018-08-27 09:12:46.675 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgr221_00_000
2018-08-27 09:12:46.677 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgr221_00_000
2018-08-27 09:12:46.680 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rfwc5_00_000
2018-08-27 09:12:46.682 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen06_00_000
2018-08-27 09:12:46.684 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_45602_00_000
2018-08-27 09:12:46.686 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_sm103_00_000
2018-08-27 09:12:46.689 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_ykfcon_00_000
2018-08-27 09:12:46.691 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:brk_zcombo_00_000
2018-08-27 09:12:46.693 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrpa1_00_000
2018-08-27 09:12:46.695 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_tiltzwave2_00_000
2018-08-27 09:12:46.697 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_ix32_00_000
2018-08-27 09:12:46.699 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_ix32_00_000
2018-08-27 09:12:46.701 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:idlock_idl101_00_000
2018-08-27 09:12:46.703 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw3003_00_000
2018-08-27 09:12:46.706 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw130_00_000
2018-08-27 09:12:46.708 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw130_00_000
2018-08-27 09:12:46.710 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw130_00_000
2018-08-27 09:12:46.712 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_st814_00_000
2018-08-27 09:12:46.714 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc11_00_000
2018-08-27 09:12:46.716 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:logic_zhc5010_00_000
2018-08-27 09:12:46.718 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:logic_zhc5010_00_000
2018-08-27 09:12:46.720 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:homeseer_hswd100_00_000
2018-08-27 09:12:46.723 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs212_00_000
2018-08-27 09:12:46.725 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgdw002_00_000
2018-08-27 09:12:46.727 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgdw002_00_000
2018-08-27 09:12:46.729 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrm222_00_000
2018-08-27 09:12:46.731 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrm222_00_000
2018-08-27 09:12:46.733 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrm222_00_000
2018-08-27 09:12:46.735 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_asrzw_00_000
2018-08-27 09:12:46.738 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz65d_00_000
2018-08-27 09:12:46.740 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz65d_00_000
2018-08-27 09:12:46.742 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pst02a_00_000
2018-08-27 09:12:46.744 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:inovelli_zw37_00_000
2018-08-27 09:12:46.746 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgk101_00_000
2018-08-27 09:12:46.748 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgk101_00_000
2018-08-27 09:12:46.750 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgk101_00_000
2018-08-27 09:12:46.752 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zdm230_00_000
2018-08-27 09:12:46.755 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:honeywell_th8320zw_00_000
2018-08-27 09:12:46.757 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:honeywell_th8320zw_00_000
2018-08-27 09:12:46.759 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct101_00_000
2018-08-27 09:12:46.761 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct101_00_000
2018-08-27 09:12:46.763 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eurotronic_cometz_00_000
2018-08-27 09:12:46.765 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eurotronic_cometz_00_000
2018-08-27 09:12:46.767 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:polycontrol_btzu125_00_000
2018-08-27 09:12:46.769 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:polycontrol_btzu125_00_000
2018-08-27 09:12:46.772 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzpd3_00_000
2018-08-27 09:12:46.774 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dlink_dchz110_00_000
2018-08-27 09:12:46.776 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen21_00_000
2018-08-27 09:12:46.778 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw6302_00_000
2018-08-27 09:12:46.780 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_m4173_00_000
2018-08-27 09:12:46.782 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc19_00_000
2018-08-27 09:12:46.785 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan071a_00_000
2018-08-27 09:12:46.787 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_eu2_00_000
2018-08-27 09:12:46.789 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz55d_00_000
2018-08-27 09:12:46.791 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_00_000
2018-08-27 09:12:46.793 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_00_000
2018-08-27 09:12:46.795 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_00_000
2018-08-27 09:12:46.797 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ha04_00_000
2018-08-27 09:12:46.800 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrgbw_00_000
2018-08-27 09:12:46.802 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrgbw_00_000
2018-08-27 09:12:46.804 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrgbw_00_000
2018-08-27 09:12:46.806 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgrgbw_00_000
2018-08-27 09:12:46.808 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_010101_00_000
2018-08-27 09:12:46.811 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_gejasco14321_00_000
2018-08-27 09:12:46.813 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rcs_tz43_00_000
2018-08-27 09:12:46.815 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:thermofloor_tf016_00_000
2018-08-27 09:12:46.817 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_dx1cgz_00_000
2018-08-27 09:12:46.819 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wa105dbz_00_000
2018-08-27 09:12:46.821 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wa105dbz_00_000
2018-08-27 09:12:46.823 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ufairy_zse02_00_000
2018-08-27 09:12:46.825 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:nodon_crc3100_00_000
2018-08-27 09:12:46.827 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ha01c_00_000
2018-08-27 09:12:46.829 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhnd_00_000
2018-08-27 09:12:46.831 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_zme05431_00_000
2018-08-27 09:12:46.833 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw20r_00_000
2018-08-27 09:12:46.835 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhad_00_000
2018-08-27 09:12:46.837 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_009204_00_000
2018-08-27 09:12:46.839 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz04_00_000
2018-08-27 09:12:46.841 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:sigma_zwck8_00_000
2018-08-27 09:12:46.844 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrp03_00_000
2018-08-27 09:12:46.846 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_heatingcontrol_00_000
2018-08-27 09:12:46.848 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_ad142_00_000
2018-08-27 09:12:46.850 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dlink_dchz310_00_000
2018-08-27 09:12:46.852 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_ad146_00_000
2018-08-27 09:12:46.854 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.856 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.858 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.860 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.862 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.864 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.866 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.868 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.870 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.872 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs211_00_000
2018-08-27 09:12:46.874 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:systemair_29990_00_000
2018-08-27 09:12:46.876 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_gctbz48_00_000
2018-08-27 09:12:46.878 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz08_00_000
2018-08-27 09:12:46.881 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:steinel_is1402_00_000
2018-08-27 09:12:46.883 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:steinel_is1402_00_000
2018-08-27 09:12:46.885 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhvd_00_000
2018-08-27 09:12:46.887 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vda_vitrumieuboiler_00_000
2018-08-27 09:12:46.889 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_ishutter_00_000
2018-08-27 09:12:46.891 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_ishutter_00_000
Log Part 3:
2018-08-27 09:12:46.893 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:nodon_msp31x1_00_000
2018-08-27 09:12:46.895 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:thermofloor_tf016_01_008
2018-08-27 09:12:46.897 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan081a_00_000
2018-08-27 09:12:46.899 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zs6301_00_000
2018-08-27 09:12:46.901 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_dthermz5_00_000
2018-08-27 09:12:46.903 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen07_00_000
2018-08-27 09:12:46.905 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd212_00_000
2018-08-27 09:12:46.907 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd212_00_000
2018-08-27 09:12:46.910 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd212_00_000
2018-08-27 09:12:46.912 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd212_00_000
2018-08-27 09:12:46.914 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9540n_00_000
2018-08-27 09:12:46.916 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9540n_00_000
2018-08-27 09:12:46.918 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:widom_wds_00_000
2018-08-27 09:12:46.920 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_004407_01_000
2018-08-27 09:12:46.922 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme06443_00_000
2018-08-27 09:12:46.924 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme06443_00_000
2018-08-27 09:12:46.926 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_tagreader_00_000
2018-08-27 09:12:46.928 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zxt120_00_000
2018-08-27 09:12:46.930 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zxt120_00_000
2018-08-27 09:12:46.932 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zxt120_00_000
2018-08-27 09:12:46.935 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw3102_00_000
2018-08-27 09:12:46.937 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz68_00_000
2018-08-27 09:12:46.939 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz68_00_000
2018-08-27 09:12:46.941 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw116_00_000
2018-08-27 09:12:46.943 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw116_00_000
2018-08-27 09:12:46.945 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw116_00_000
2018-08-27 09:12:46.947 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_506119_00_000
2018-08-27 09:12:46.949 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw112_00_000
2018-08-27 09:12:46.951 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw112_00_000
2018-08-27 09:12:46.953 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw112_00_000
2018-08-27 09:12:46.955 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw112_00_000
2018-08-27 09:12:46.957 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_lsm15_00_000
2018-08-27 09:12:46.959 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_swes01_00_000
2018-08-27 09:12:46.961 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zw4101_00_000
2018-08-27 09:12:46.963 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_pan11_00_000
2018-08-27 09:12:46.965 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhcd_04_001
2018-08-27 09:12:46.967 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhcd_04_001
2018-08-27 09:12:46.970 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:econet_gr105n_00_000
2018-08-27 09:12:46.972 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fakro_vmzsolarplus_00_000
2018-08-27 09:12:46.974 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100_00_000
2018-08-27 09:12:46.976 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100_00_000
2018-08-27 09:12:46.978 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100_00_000
2018-08-27 09:12:46.980 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100_00_000
2018-08-27 09:12:46.982 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100_00_000
2018-08-27 09:12:46.984 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct100_00_000
2018-08-27 09:12:46.987 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_intermaticca3000_00_000
2018-08-27 09:12:46.989 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge14292_00_000
2018-08-27 09:12:46.991 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_duwrpt_00_000
2018-08-27 09:12:46.993 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_sf812_00_000
2018-08-27 09:12:46.996 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:northq_nq9021_00_000
2018-08-27 09:12:46.998 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc18_00_000
2018-08-27 09:12:47.000 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_m4172_00_000
2018-08-27 09:12:47.001 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw139_00_000
2018-08-27 09:12:47.004 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw139_00_000
2018-08-27 09:12:47.006 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw139_00_000
2018-08-27 09:12:47.008 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs512il_00_000
2018-08-27 09:12:47.010 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dragontech_wd100_00_000
2018-08-27 09:12:47.012 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dragontech_wd100_00_000
2018-08-27 09:12:47.014 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd120_00_000
2018-08-27 09:12:47.016 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd120_00_000
2018-08-27 09:12:47.018 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_st815_00_000
2018-08-27 09:12:47.020 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgt001_00_000
2018-08-27 09:12:47.022 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc10_00_000
2018-08-27 09:12:47.024 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs521_00_000
2018-08-27 09:12:47.026 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_ps15emz51_00_000
2018-08-27 09:12:47.027 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wa00z1_00_000
2018-08-27 09:12:47.029 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc14_00_000
2018-08-27 09:12:47.031 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_lfm20_00_000
2018-08-27 09:12:47.033 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_nzw36_01_000
2018-08-27 09:12:47.035 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct200_00_000
2018-08-27 09:12:47.037 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_p1dongle_00_000
2018-08-27 09:12:47.039 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zs6101_00_000
2018-08-27 09:12:47.041 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_50x5xx_00_000
2018-08-27 09:12:47.043 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an158_00_000
2018-08-27 09:12:47.045 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_35931_00_000
2018-08-27 09:12:47.047 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:stelpro_stzw402_00_000
2018-08-27 09:12:47.049 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_06436_00_000
2018-08-27 09:12:47.051 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zmerc2_00_000
2018-08-27 09:12:47.053 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_gezw4004_00_000
2018-08-27 09:12:47.056 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pab01_00_000
2018-08-27 09:12:47.058 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_014g0160_00_000
2018-08-27 09:12:47.060 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd220_00_000
2018-08-27 09:12:47.062 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd220_00_000
2018-08-27 09:12:47.064 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd220_00_000
2018-08-27 09:12:47.066 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd220_00_000
2018-08-27 09:12:47.068 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd220_00_000
2018-08-27 09:12:47.070 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd220_00_000
2018-08-27 09:12:47.072 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wapirz_00_000
2018-08-27 09:12:47.074 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs511il_00_000
2018-08-27 09:12:47.076 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ha05_00_000
2018-08-27 09:12:47.078 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fakro_vmzsolar_00_000
2018-08-27 09:12:47.080 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kichler_12387_00_000
2018-08-27 09:12:47.082 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan16_01_002
2018-08-27 09:12:47.084 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan16_01_002
2018-08-27 09:12:47.086 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_09813_00_000
2018-08-27 09:12:47.088 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt2792_00_000
2018-08-27 09:12:47.090 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan04_00_000
2018-08-27 09:12:47.092 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan04_00_000
2018-08-27 09:12:47.094 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan04_00_000
2018-08-27 09:12:47.096 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_ad147_00_000
2018-08-27 09:12:47.098 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zse40_00_000
2018-08-27 09:12:47.100 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zipato_nenaspd01z_00_000
2018-08-27 09:12:47.101 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_ssr302_00_000
2018-08-27 09:12:47.103 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrf01_00_000
2018-08-27 09:12:47.105 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrf01_00_000
2018-08-27 09:12:47.107 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1601_00_000
2018-08-27 09:12:47.109 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1601_00_000
2018-08-27 09:12:47.111 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan08_00_000
2018-08-27 09:12:47.113 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_506219_00_000
2018-08-27 09:12:47.115 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhaa_00_000
2018-08-27 09:12:47.117 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zrp200_00_000
2018-08-27 09:12:47.119 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw15sm_00_000
2018-08-27 09:12:47.121 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_outdoorswitch_00_000
2018-08-27 09:12:47.123 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:sigma_m4179e_00_000
2018-08-27 09:12:47.125 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_hkzws001_00_000
2018-08-27 09:12:47.127 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:elexa_dmmz1_00_000
2018-08-27 09:12:47.130 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimolite_00_000
2018-08-27 09:12:47.132 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimolite_00_000
2018-08-27 09:12:47.134 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimolite_00_000
2018-08-27 09:12:47.136 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimolite_00_000
2018-08-27 09:12:47.138 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimolite_00_000
2018-08-27 09:12:47.140 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:diehl_sesfszw_00_000
2018-08-27 09:12:47.142 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:locstar_ls8015zw_00_000
2018-08-27 09:12:47.144 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_pst021b_00_000
2018-08-27 09:12:47.146 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrpd3_00_000
2018-08-27 09:12:47.149 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fakro_zws12_00_000
2018-08-27 09:12:47.150 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fakro_zws12_00_000
2018-08-27 09:12:47.152 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zl7101_00_000
2018-08-27 09:12:47.154 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz37_00_000
2018-08-27 09:12:47.156 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh10pm25wa_00_000
2018-08-27 09:12:47.158 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh10pm25wa_00_000
2018-08-27 09:12:47.160 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_es61_01_036
2018-08-27 09:12:47.162 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_zen23_00_000
2018-08-27 09:12:47.164 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw096_00_000
2018-08-27 09:12:47.166 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw096_00_000
2018-08-27 09:12:47.168 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw096_00_000
2018-08-27 09:12:47.170 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw096_00_000
2018-08-27 09:12:47.172 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgcd001_00_000
2018-08-27 09:12:47.174 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_tse03_00_000
2018-08-27 09:12:47.176 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_zwesj300_00_000
2018-08-27 09:12:47.178 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_t100_00_000
2018-08-27 09:12:47.186 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_12729_00_000
2018-08-27 09:12:47.189 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_alarmsound_00_000
2018-08-27 09:12:47.191 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs222_00_000
2018-08-27 09:12:47.194 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs222_00_000
2018-08-27 09:12:47.196 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_hsm02_00_000
2018-08-27 09:12:47.199 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_hsm02_00_000
2018-08-27 09:12:47.201 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kwikset_914trl_00_000
2018-08-27 09:12:47.204 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_energyswitch_00_000
2018-08-27 09:12:47.210 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_dp32z_01_036
2018-08-27 09:12:47.213 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw062_00_000
2018-08-27 09:12:47.215 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw062_00_000
2018-08-27 09:12:47.218 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw062_00_000
2018-08-27 09:12:47.220 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgbs001_00_000
2018-08-27 09:12:47.223 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgbs001_00_000
2018-08-27 09:12:47.225 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgbs001_00_000
2018-08-27 09:12:47.228 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgbs001_00_000
2018-08-27 09:12:47.230 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgbs001_00_000
2018-08-27 09:12:47.233 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgbs001_00_000
2018-08-27 09:12:47.235 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzpa1_00_000
2018-08-27 09:12:47.237 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzpa1_00_000
2018-08-27 09:12:47.239 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zmeft_00_000
2018-08-27 09:12:47.241 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_00_000
2018-08-27 09:12:47.243 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_00_000
2018-08-27 09:12:47.245 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_00_000
2018-08-27 09:12:47.246 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_00_000
2018-08-27 09:12:47.248 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_00_000
2018-08-27 09:12:47.250 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme06437_00_000
2018-08-27 09:12:47.252 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgss001_00_000
2018-08-27 09:12:47.254 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgss001_00_000
2018-08-27 09:12:47.256 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhod_00_000
2018-08-27 09:12:47.258 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_05431_00_000
2018-08-27 09:12:47.260 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt02646_00_000
2018-08-27 09:12:47.262 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:logic_zhc5010_02_000
2018-08-27 09:12:47.264 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:telldus_tzdw100_00_000
2018-08-27 09:12:47.266 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan11_00_000
2018-08-27 09:12:47.267 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan11_00_000
2018-08-27 09:12:47.269 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan11_00_000
2018-08-27 09:12:47.271 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pse02_00_000
2018-08-27 09:12:47.273 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:elexa_dmwv1_00_000
2018-08-27 09:12:47.275 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dz1kd_00_000
2018-08-27 09:12:47.277 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3102_00_000
2018-08-27 09:12:47.279 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3102_00_000
2018-08-27 09:12:47.281 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3102_00_000
2018-08-27 09:12:47.283 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3102_00_000
2018-08-27 09:12:47.285 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3102_00_000
2018-08-27 09:12:47.287 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb05_00_000
2018-08-27 09:12:47.289 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_molite_00_000
2018-08-27 09:12:47.290 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_molite_00_000
2018-08-27 09:12:47.292 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_nasds01z_00_000
2018-08-27 09:12:47.294 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc26_00_000
2018-08-27 09:12:47.296 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz79_00_000
2018-08-27 09:12:47.298 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:greenwave_gwpn6_00_000
2018-08-27 09:12:47.300 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zoozzse08_00_000
2018-08-27 09:12:47.302 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zse30_00_000
2018-08-27 09:12:47.304 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zse30_00_000
2018-08-27 09:12:47.306 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_ws15z_00_000
2018-08-27 09:12:47.308 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_ws15z_00_000
2018-08-27 09:12:47.310 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45605_00_000
2018-08-27 09:12:47.312 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_xr524_00_000
2018-08-27 09:12:47.314 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zdw120_00_000
2018-08-27 09:12:47.315 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:graber_rsz1_00_000
2018-08-27 09:12:47.317 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb09_00_000
2018-08-27 09:12:47.319 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9517_00_000
2018-08-27 09:12:47.321 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_tps411_00_000
2018-08-27 09:12:47.323 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:telldus_tzwp100_00_000
2018-08-27 09:12:47.325 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhia_00_000
2018-08-27 09:12:47.327 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45609_00_000
2018-08-27 09:12:47.329 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45609_00_000
2018-08-27 09:12:47.331 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zts110_00_000
2018-08-27 09:12:47.333 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zts110_00_000
2018-08-27 09:12:47.335 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw4102_00_000
Log Part 4:
2018-08-27 09:12:47.336 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_gepluginsmartswitch_00_000
2018-08-27 09:12:47.338 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_psp05_00_000
2018-08-27 09:12:47.340 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pat02b_00_000
2018-08-27 09:12:47.342 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_14280_00_000
2018-08-27 09:12:47.344 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme05459_00_000
2018-08-27 09:12:47.346 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_sirenalarm_00_000
2018-08-27 09:12:47.348 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_sirenalarm_00_000
2018-08-27 09:12:47.350 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_scn01_00_000
2018-08-27 09:12:47.352 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_scn01_00_000
2018-08-27 09:12:47.354 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsd37_00_000
2018-08-27 09:12:47.356 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsd37_00_000
2018-08-27 09:12:47.358 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:graber_csz1_00_000
2018-08-27 09:12:47.360 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wd500z_00_000
2018-08-27 09:12:47.362 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw120_00_000
2018-08-27 09:12:47.364 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw120_00_000
2018-08-27 09:12:47.366 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_iplugdim_00_000
2018-08-27 09:12:47.368 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_doorwindowsensor_00_000
2018-08-27 09:12:47.370 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_doorwindowsensor_00_000
2018-08-27 09:12:47.372 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qees_p313a_00_000
2018-08-27 09:12:47.374 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_009402_01_014
2018-08-27 09:12:47.376 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_flfzwave5r1_00_000
2018-08-27 09:12:47.378 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw4006_00_000
2018-08-27 09:12:47.380 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_14288_00_000
2018-08-27 09:12:47.382 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw4002_00_000
2018-08-27 09:12:47.384 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw4002_00_000
2018-08-27 09:12:47.386 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kichler_15dc200_00_000
2018-08-27 09:12:47.388 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:inovelli_nzw39_00_000
2018-08-27 09:12:47.390 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:coqon_psmz0001_00_000
2018-08-27 09:12:47.392 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_ngd00z4_00_000
2018-08-27 09:12:47.394 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_ngd00z4_00_000
2018-08-27 09:12:47.396 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zdw103_00_000
2018-08-27 09:12:47.398 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_hs1ds_00_000
2018-08-27 09:12:47.400 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:homeseer_ezmotionexpress_00_000
2018-08-27 09:12:47.402 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:homeseer_ezmotionexpress_00_000
2018-08-27 09:12:47.404 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pst02b_00_000
2018-08-27 09:12:47.406 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:sensative_1101011_00_000
2018-08-27 09:12:47.408 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge14294_00_000
2018-08-27 09:12:47.410 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:prodrive_ed20_00_000
2018-08-27 09:12:47.413 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhja_00_000
2018-08-27 09:12:47.415 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_doorwindowsensor_00_000
2018-08-27 09:12:47.417 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen22_00_000
2018-08-27 09:12:47.419 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ufairy_grb33_00_000
2018-08-27 09:12:47.421 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ufairy_grb33_00_000
2018-08-27 09:12:47.423 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc12_00_000
2018-08-27 09:12:47.425 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_pid11995_00_000
2018-08-27 09:12:47.426 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_pid11995_00_000
2018-08-27 09:12:47.428 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_lcz251_00_000
2018-08-27 09:12:47.430 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vri06_00_000
2018-08-27 09:12:47.432 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vri06_00_000
2018-08-27 09:12:47.434 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw20rm_00_000
2018-08-27 09:12:47.436 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:schlage_be468_00_000
2018-08-27 09:12:47.438 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_swiidplug_00_000
2018-08-27 09:12:47.440 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9500_00_000
2018-08-27 09:12:47.441 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_lom15_00_000
2018-08-27 09:12:47.443 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zrm230_00_000
2018-08-27 09:12:47.445 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_05443_00_000
2018-08-27 09:12:47.447 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwn333_00_000
2018-08-27 09:12:47.449 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme05461_00_000
2018-08-27 09:12:47.451 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:domitech_ze27_00_000
2018-08-27 09:12:47.453 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:domitech_ze27_00_000
2018-08-27 09:12:47.455 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:domitech_ze27_00_000
2018-08-27 09:12:47.457 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrmx11lz_00_000
2018-08-27 09:12:47.459 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrcs2mrx1_00_000
2018-08-27 09:12:47.460 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_ltm5_00_000
2018-08-27 09:12:47.462 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_004001_00_000
2018-08-27 09:12:47.464 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc35_00_000
2018-08-27 09:12:47.466 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_tzemt400bb32maa_00_000
2018-08-27 09:12:47.468 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_tzemt400bb32maa_00_000
2018-08-27 09:12:47.470 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_tzemt400bb32maa_00_000
2018-08-27 09:12:47.472 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_phpse02_00_000
2018-08-27 09:12:47.473 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_dws01_00_000
2018-08-27 09:12:47.475 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:polycontrol_btze_00_000
2018-08-27 09:12:47.477 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:logic_lhc5031_00_062
2018-08-27 09:12:47.479 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimo2_00_000
2018-08-27 09:12:47.481 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_mimo2_00_000
2018-08-27 09:12:47.483 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:siegeniaaubi_sensoair_00_000
2018-08-27 09:12:47.485 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan06_00_000
2018-08-27 09:12:47.487 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan06_00_000
2018-08-27 09:12:47.488 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.490 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.492 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.494 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.496 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.498 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.500 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.502 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw056_00_000
2018-08-27 09:12:47.504 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an179_00_000
2018-08-27 09:12:47.505 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an179_00_000
2018-08-27 09:12:47.507 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an179_00_000
2018-08-27 09:12:47.509 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:widom_wps104_00_000
2018-08-27 09:12:47.511 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zfm80_00_000
2018-08-27 09:12:47.513 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs212_00_000
2018-08-27 09:12:47.515 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs212_00_000
2018-08-27 09:12:47.517 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dragontech_pa100_00_000
2018-08-27 09:12:47.519 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qees_qeeswall_00_000
2018-08-27 09:12:47.521 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_adt8020_00_000
2018-08-27 09:12:47.523 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:chromagic_sm103_00_000
2018-08-27 09:12:47.524 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zipato_rgbwe27zw_00_000
2018-08-27 09:12:47.526 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwmrsm1_00_000
2018-08-27 09:12:47.528 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_le120_00_000
2018-08-27 09:12:47.530 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ca600_00_000
2018-08-27 09:12:47.532 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an181_00_000
2018-08-27 09:12:47.534 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ha20_00_000
2018-08-27 09:12:47.536 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_tiltzwave25eco_00_000
2018-08-27 09:12:47.538 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgwp101_00_000
2018-08-27 09:12:47.540 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgpb101_00_000
2018-08-27 09:12:47.541 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgpb101_00_000
2018-08-27 09:12:47.543 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgpb101_00_000
2018-08-27 09:12:47.545 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgpb101_00_000
2018-08-27 09:12:47.547 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:elexa_dmwd1_00_000
2018-08-27 09:12:47.549 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_123610_00_000
2018-08-27 09:12:47.551 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zrw230_00_000
2018-08-27 09:12:47.553 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ca3500_00_000
2018-08-27 09:12:47.555 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:goodway_td1311_00_000
2018-08-27 09:12:47.557 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb54_00_000
2018-08-27 09:12:47.559 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_srt323_00_000
2018-08-27 09:12:47.560 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw075_00_000
2018-08-27 09:12:47.562 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw075_00_000
2018-08-27 09:12:47.564 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_eu1_00_000
2018-08-27 09:12:47.566 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9542_00_000
2018-08-27 09:12:47.568 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9542_00_000
2018-08-27 09:12:47.570 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ha03_00_000
2018-08-27 09:12:47.572 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dragontech_ws100_00_000
2018-08-27 09:12:47.574 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsi_00_000
2018-08-27 09:12:47.576 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw089_00_000
2018-08-27 09:12:47.577 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw089_00_000
2018-08-27 09:12:47.579 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw089_00_000
2018-08-27 09:12:47.581 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_hsp02_00_000
2018-08-27 09:12:47.583 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_hsp02_00_000
2018-08-27 09:12:47.585 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhcd_00_000
2018-08-27 09:12:47.587 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zipato_zd2102_00_000
2018-08-27 09:12:47.589 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhld_00_000
2018-08-27 09:12:47.590 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhld_00_000
2018-08-27 09:12:47.592 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_009303_00_000
2018-08-27 09:12:47.594 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_pid15903_00_000
2018-08-27 09:12:47.596 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_duw064374_00_000
2018-08-27 09:12:47.598 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_hkzwso03_00_000
2018-08-27 09:12:47.600 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt02648_00_000
2018-08-27 09:12:47.602 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_012501_00_000
2018-08-27 09:12:47.604 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd210_00_000
2018-08-27 09:12:47.606 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd210_00_000
2018-08-27 09:12:47.607 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd210_00_000
2018-08-27 09:12:47.609 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_05433_00_000
2018-08-27 09:12:47.611 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw500d_00_000
2018-08-27 09:12:47.613 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt2652_00_000
2018-08-27 09:12:47.615 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fakro_arz_00_000
2018-08-27 09:12:47.617 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eurotronic_stellaz_00_000
2018-08-27 09:12:47.619 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_ldm15w_00_000
2018-08-27 09:12:47.621 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dz6hd_00_000
2018-08-27 09:12:47.623 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzmx11lz_00_000
2018-08-27 09:12:47.625 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_smartdoorsensor_00_000
2018-08-27 09:12:47.627 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:bonig_pope005206_00_000
2018-08-27 09:12:47.629 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zd2201_00_000
2018-08-27 09:12:47.630 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrr151lz_00_000
2018-08-27 09:12:47.632 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_12727_00_000
2018-08-27 09:12:47.635 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw098_00_000
2018-08-27 09:12:47.637 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw098_00_000
2018-08-27 09:12:47.639 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw098_00_000
2018-08-27 09:12:47.641 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_008
2018-08-27 09:12:47.643 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_008
2018-08-27 09:12:47.645 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_008
2018-08-27 09:12:47.647 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhba_00_000
2018-08-27 09:12:47.649 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:schlage_fe599nx_00_000
2018-08-27 09:12:47.651 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw1001_00_000
2018-08-27 09:12:47.653 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_zen21_00_000
2018-08-27 09:12:47.655 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw15r_00_000
2018-08-27 09:12:47.656 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb45_00_000
2018-08-27 09:12:47.658 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome__00_000
2018-08-27 09:12:47.660 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zse40_00_000
2018-08-27 09:12:47.664 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt2756_00_000
2018-08-27 09:12:47.666 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_tbz48_00_000
2018-08-27 09:12:47.667 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_wwa02_00_000
2018-08-27 09:12:47.669 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_wwa02_00_000
2018-08-27 09:12:47.671 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw090_00_000
2018-08-27 09:12:47.673 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw090_00_000
2018-08-27 09:12:47.675 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw090_00_000
2018-08-27 09:12:47.677 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zyxel_st812_00_000
2018-08-27 09:12:47.679 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhp220_00_000
2018-08-27 09:12:47.681 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:amc_zdsud10_00_000
2018-08-27 09:12:47.683 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_hkzwms02_00_000
2018-08-27 09:12:47.685 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw122_00_000
2018-08-27 09:12:47.687 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsd31_00_000
2018-08-27 09:12:47.689 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:inovelli_nzw37_00_000
2018-08-27 09:12:47.691 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs411_00_000
2018-08-27 09:12:47.693 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwn323m_00_000
2018-08-27 09:12:47.695 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhud_00_000
2018-08-27 09:12:47.697 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhzd_00_000
2018-08-27 09:12:47.699 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:nodon_cws3101_00_000
2018-08-27 09:12:47.701 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_03_002
2018-08-27 09:12:47.703 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_03_002
2018-08-27 09:12:47.705 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_03_002
2018-08-27 09:12:47.707 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgms001_03_002
2018-08-27 09:12:47.709 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb28_00_000
2018-08-27 09:12:47.711 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_rgbbulb_00_000
2018-08-27 09:12:47.713 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_rgbbulb_00_000
2018-08-27 09:12:47.715 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhdd_00_000
2018-08-27 09:12:47.717 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:august_asl03_00_000
2018-08-27 09:12:47.718 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45603_00_000
Log Part 5:
2018-08-27 09:12:47.720 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45603_00_000
2018-08-27 09:12:47.722 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd110_00_000
2018-08-27 09:12:47.724 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_floodsensor_00_000
2018-08-27 09:12:47.726 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_floodsensor_00_000
2018-08-27 09:12:47.728 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_ssa1_00_000
2018-08-27 09:12:47.730 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_ssa1_00_000
2018-08-27 09:12:47.732 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_ssa1_00_000
2018-08-27 09:12:47.734 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zl7431_00_000
2018-08-27 09:12:47.735 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zl7431_00_000
2018-08-27 09:12:47.737 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zl7431_00_000
2018-08-27 09:12:47.739 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:greenwave_gwpn1_03_000
2018-08-27 09:12:47.741 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc24_00_000
2018-08-27 09:12:47.743 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc24_00_000
2018-08-27 09:12:47.745 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_digitalhomesystems_00_000
2018-08-27 09:12:47.747 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45607_00_000
2018-08-27 09:12:47.748 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zg8101_00_000
2018-08-27 09:12:47.750 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_507801_00_000
2018-08-27 09:12:47.752 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wo15z_00_000
2018-08-27 09:12:47.754 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_sp814_00_000
2018-08-27 09:12:47.756 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:erone_hmdw001_00_000
2018-08-27 09:12:47.758 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:nexia_db100z_00_000
2018-08-27 09:12:47.760 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:seco_clamp_00_000
2018-08-27 09:12:47.762 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zrc100_00_000
2018-08-27 09:12:47.764 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zrc100_00_000
2018-08-27 09:12:47.766 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgkf601_00_000
2018-08-27 09:12:47.767 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgkf601_00_000
2018-08-27 09:12:47.769 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:connecthome_ch201_00_000
2018-08-27 09:12:47.771 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zd2105_00_000
2018-08-27 09:12:47.773 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrs15_00_000
2018-08-27 09:12:47.775 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrs15_00_000
2018-08-27 09:12:47.777 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh9co2wd_00_000
2018-08-27 09:12:47.779 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh9co2wd_00_000
2018-08-27 09:12:47.781 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ingersollecolink_dwzwave1_00_000
2018-08-27 09:12:47.783 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:devolo_mt2653_00_000
2018-08-27 09:12:47.784 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_lb60z1_00_000
2018-08-27 09:12:47.786 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vemmio_ds100_00_000
2018-08-27 09:12:47.788 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_1122r_01_004
2018-08-27 09:12:47.790 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_5082xx_00_000
2018-08-27 09:12:47.792 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_itemp_00_000
2018-08-27 09:12:47.794 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_itemp_00_000
2018-08-27 09:12:47.796 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_mt02650_00_000
2018-08-27 09:12:47.798 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_23_023
2018-08-27 09:12:47.799 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_23_023
2018-08-27 09:12:47.801 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_hs1sa_00_000
2018-08-27 09:12:47.803 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh6hp_00_000
2018-08-27 09:12:47.805 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_507601_00_000
2018-08-27 09:12:47.807 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vda_satellitevi_00_000
2018-08-27 09:12:47.809 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_powerplug_00_000
2018-08-27 09:12:47.811 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_powerplug_00_000
2018-08-27 09:12:47.812 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rimport_zmeeraz2_00_000
2018-08-27 09:12:47.814 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveproducts_ws100_00_000
2018-08-27 09:12:47.816 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:reitz_duw064381_00_000
2018-08-27 09:12:47.818 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_01_009
2018-08-27 09:12:47.820 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_01_009
2018-08-27 09:12:47.822 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_01_009
2018-08-27 09:12:47.823 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_01_009
2018-08-27 09:12:47.825 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_01_009
2018-08-27 09:12:47.827 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_01_009
2018-08-27 09:12:47.829 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_009402_00_000
2018-08-27 09:12:47.831 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw095_00_000
2018-08-27 09:12:47.833 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw095_00_000
2018-08-27 09:12:47.835 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw15s_00_000
2018-08-27 09:12:47.837 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzpd32_00_000
2018-08-27 09:12:47.839 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:sigma_smpz701u_00_000
2018-08-27 09:12:47.841 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge12725_00_000
2018-08-27 09:12:47.843 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zweather_00_000
2018-08-27 09:12:47.845 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_motionsensorin_00_000
2018-08-27 09:12:47.846 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct80_00_000
2018-08-27 09:12:47.848 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct80_00_000
2018-08-27 09:12:47.850 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwnrsm2_00_000
2018-08-27 09:12:47.853 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pad02_00_000
2018-08-27 09:12:47.855 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zwaveme_zme05433_00_000
2018-08-27 09:12:47.857 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_wtrfid_00_000
2018-08-27 09:12:47.859 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_wtrfid_00_000
2018-08-27 09:12:47.861 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_zen24_00_000
2018-08-27 09:12:47.862 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwnrsm1plus_00_000
2018-08-27 09:12:47.864 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_hs1htz_00_000
2018-08-27 09:12:47.866 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhbd_00_000
2018-08-27 09:12:47.868 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_swm301_00_000
2018-08-27 09:12:47.870 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw099_00_000
2018-08-27 09:12:47.872 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw099_00_000
2018-08-27 09:12:47.874 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw099_00_000
2018-08-27 09:12:47.876 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw099_00_000
2018-08-27 09:12:47.878 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:horstmann_hrt4zw_00_000
2018-08-27 09:12:47.880 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhsd_00_000
2018-08-27 09:12:47.882 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hogar_htp4s1fb_02_002
2018-08-27 09:12:47.884 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zrc90_00_000
2018-08-27 09:12:47.886 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zrc90_00_000
2018-08-27 09:12:47.888 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_zrc90_00_000
2018-08-27 09:12:47.890 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_dhsitswpdhs_00_000
2018-08-27 09:12:47.891 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:willis_zen20_00_000
2018-08-27 09:12:47.893 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhda_00_000
2018-08-27 09:12:47.895 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:homeseer_hsds100_00_000
2018-08-27 09:12:47.898 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw4005_00_000
2018-08-27 09:12:47.900 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_wv01_00_000
2018-08-27 09:12:47.902 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fortrezz_wv01_00_000
2018-08-27 09:12:47.904 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_easyplug_00_000
2018-08-27 09:12:47.906 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_pope700168_00_000
2018-08-27 09:12:47.909 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd446_00_000
2018-08-27 09:12:47.911 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh8fc_01_002
2018-08-27 09:12:47.913 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb29_00_000
2018-08-27 09:12:47.915 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsb29_00_000
2018-08-27 09:12:47.917 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:chromagic_hsm02_00_000
2018-08-27 09:12:47.919 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zipato_hmhs1ca_00_000
2018-08-27 09:12:47.921 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.923 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.925 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.926 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.928 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.930 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.932 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.933 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.935 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.937 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_02_001
2018-08-27 09:12:47.939 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwnsc7_00_000
2018-08-27 09:12:47.940 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_lc13_00_000
2018-08-27 09:12:47.942 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_lc13_00_000
2018-08-27 09:12:47.944 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_lc13_00_000
2018-08-27 09:12:47.946 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_ps15z_00_000
2018-08-27 09:12:47.948 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zw500dm_00_000
2018-08-27 09:12:47.949 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc06_00_000
2018-08-27 09:12:47.951 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:inovelli_nzw36_00_000
2018-08-27 09:12:47.953 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_507900_00_000
2018-08-27 09:12:47.955 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_123665_00_000
2018-08-27 09:12:47.957 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_rzp03_00_000
2018-08-27 09:12:47.958 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_lrmas_00_000
2018-08-27 09:12:47.960 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:oomi_oomiplug_00_000
2018-08-27 09:12:47.962 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw088_01_000
2018-08-27 09:12:47.964 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw088_01_000
2018-08-27 09:12:47.965 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw088_01_000
2018-08-27 09:12:47.967 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zir010_00_000
2018-08-27 09:12:47.969 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_tps412_00_000
2018-08-27 09:12:47.971 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rcs_tbz48_00_000
2018-08-27 09:12:47.972 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_507501_00_000
2018-08-27 09:12:47.974 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:dlink_dchz120_00_000
2018-08-27 09:12:47.976 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:isurpass_dx1wl_00_000
2018-08-27 09:12:47.978 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pat02a_00_000
2018-08-27 09:12:47.980 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:homeseer_ezmultipli_00_000
2018-08-27 09:12:47.982 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw4101_00_000
2018-08-27 09:12:47.984 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:enerwave_zwnbpc_00_000
2018-08-27 09:12:47.986 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_005206_00_000
2018-08-27 09:12:47.987 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_005107_01_001
2018-08-27 09:12:47.989 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_ad130_00_000
2018-08-27 09:12:47.991 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_00_000
2018-08-27 09:12:47.993 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_00_000
2018-08-27 09:12:47.995 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_00_000
2018-08-27 09:12:47.996 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1602_15_000
2018-08-27 09:12:47.998 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1602_15_000
2018-08-27 09:12:48.000 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_05438_00_000
2018-08-27 09:12:48.002 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:schlage_be369_00_000
2018-08-27 09:12:48.003 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:greenwave_gwpn5_00_000
2018-08-27 09:12:48.005 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc25_00_000
2018-08-27 09:12:48.007 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zse33_00_000
2018-08-27 09:12:48.009 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct32_00_000
2018-08-27 09:12:48.011 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct32_00_000
2018-08-27 09:12:48.012 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rtc_ct32_00_000
2018-08-27 09:12:48.014 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_45606_00_000
2018-08-27 09:12:48.016 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:hank_smpz710u_00_000
2018-08-27 09:12:48.018 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz66d_00_000
2018-08-27 09:12:48.019 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rftr9505_00_000
2018-08-27 09:12:48.021 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9534ws_00_000
2018-08-27 09:12:48.023 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:evolve_lpm15_00_000
2018-08-27 09:12:48.025 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:elexa_dmws1_00_000
2018-08-27 09:12:48.027 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_pid11994_00_000
2018-08-27 09:12:48.028 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc13_00_000
2018-08-27 09:12:48.030 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_26933_00_000
2018-08-27 09:12:48.032 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ufairy_gr105_00_000
2018-08-27 09:12:48.034 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ufairy_gr105_00_000
2018-08-27 09:12:48.036 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_pope700052_00_000
2018-08-27 09:12:48.037 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw132_00_000
2018-08-27 09:12:48.039 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsc17_00_000
2018-08-27 09:12:48.041 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:elexa_dms01_00_000
2018-08-27 09:12:48.043 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.045 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.047 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.048 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.050 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.052 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.054 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.056 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.058 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.060 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs221_01_009
2018-08-27 09:12:48.062 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:schlage_be469_00_000
2018-08-27 09:12:48.064 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_st812_00_000
2018-08-27 09:12:48.065 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:innovus_00110001_01_000
Log Part 6:
2018-08-27 09:12:48.067 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:innovus_00110001_01_000
2018-08-27 09:12:48.069 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ingersollecolink_rs200_00_000
2018-08-27 09:12:48.071 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_fs20z_00_000
2018-08-27 09:12:48.073 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgwp102_03_002
2018-08-27 09:12:48.074 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pst02c_00_000
2018-08-27 09:12:48.076 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhjd_00_000
2018-08-27 09:12:48.078 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zse09_00_000
2018-08-27 09:12:48.080 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge14295_00_000
2018-08-27 09:12:48.081 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen23_00_000
2018-08-27 09:12:48.083 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zooz_zen23_00_000
2018-08-27 09:12:48.085 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_ge14291_00_000
2018-08-27 09:12:48.087 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_ix32_06_000
2018-08-27 09:12:48.089 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:kaipule_ix32_06_000
2018-08-27 09:12:48.091 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:northq_nq9022_00_000
2018-08-27 09:12:48.093 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhtd_00_000
2018-08-27 09:12:48.095 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrd246_00_000
2018-08-27 09:12:48.096 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_zw3101_00_000
2018-08-27 09:12:48.098 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cloud_a803n_00_000
2018-08-27 09:12:48.100 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs314_00_000
2018-08-27 09:12:48.102 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mhs314_00_000
2018-08-27 09:12:48.103 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz36d_02_001
2018-08-27 09:12:48.105 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:elexa_dmof1_00_000
2018-08-27 09:12:48.107 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw111_00_000
2018-08-27 09:12:48.109 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw111_00_000
2018-08-27 09:12:48.110 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw111_00_000
2018-08-27 09:12:48.112 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_xl624_00_000
2018-08-27 09:12:48.114 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:trane_xl624_00_000
2018-08-27 09:12:48.116 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_m4179e_00_000
2018-08-27 09:12:48.118 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_509519_00_000
2018-08-27 09:12:48.119 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz67_00_000
2018-08-27 09:12:48.121 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:tkb_tz67_00_000
2018-08-27 09:12:48.123 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_se812_00_000
2018-08-27 09:12:48.125 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ca8900_00_000
2018-08-27 09:12:48.126 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vemmio_mt100_00_000
2018-08-27 09:12:48.128 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:cooper_rf9501_00_000
2018-08-27 09:12:48.130 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrs05_00_000
2018-08-27 09:12:48.132 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vrs05_00_000
2018-08-27 09:12:48.133 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_03_002
2018-08-27 09:12:48.135 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_03_002
2018-08-27 09:12:48.137 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgfs101_03_002
2018-08-27 09:12:48.139 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:danfoss_dthermz6_00_000
2018-08-27 09:12:48.140 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrl220_00_000
2018-08-27 09:12:48.142 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrl220_00_000
2018-08-27 09:12:48.144 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrl220_00_000
2018-08-27 09:12:48.146 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:yale_yrl220_00_000
2018-08-27 09:12:48.147 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vre06_00_000
2018-08-27 09:12:48.149 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_vre06_00_000
2018-08-27 09:12:48.152 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_ecolinkpirv25_00_000
2018-08-27 09:12:48.153 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_00_000
2018-08-27 09:12:48.155 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_00_000
2018-08-27 09:12:48.157 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_00_000
2018-08-27 09:12:48.159 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_00_000
2018-08-27 09:12:48.160 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_00_000
2018-08-27 09:12:48.162 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_00_000
2018-08-27 09:12:48.164 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1602_00_000
2018-08-27 09:12:48.166 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1602_00_000
2018-08-27 09:12:48.167 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzs15_00_000
2018-08-27 09:12:48.169 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everyoo_erc307_00_000
2018-08-27 09:12:48.171 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgk101_03_002
2018-08-27 09:12:48.173 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgk101_03_002
2018-08-27 09:12:48.174 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgk101_03_002
2018-08-27 09:12:48.176 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an180_00_000
2018-08-27 09:12:48.178 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:benext_plugindimmer_00_000
2018-08-27 09:12:48.180 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_ztm230_00_000
2018-08-27 09:12:48.181 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.183 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.185 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.190 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.192 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.194 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.195 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.197 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.199 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.200 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.202 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.204 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.206 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.208 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.210 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.211 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:somfy_zrtsivnode_00_000
2018-08-27 09:12:48.213 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fakro_amz_00_000
2018-08-27 09:12:48.215 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:ge_12718_00_000
2018-08-27 09:12:48.217 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:wintop_multisensor_00_000
2018-08-27 09:12:48.218 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zp3102_08_000
2018-08-27 09:12:48.220 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_pir1_00_000
2018-08-27 09:12:48.222 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs213_00_000
2018-08-27 09:12:48.224 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgs213_00_000
2018-08-27 09:12:48.225 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:philio_pan03_00_000
2018-08-27 09:12:48.227 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_02_001
2018-08-27 09:12:48.229 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_02_001
2018-08-27 09:12:48.231 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_02_001
2018-08-27 09:12:48.232 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_02_001
2018-08-27 09:12:48.234 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_02_001
2018-08-27 09:12:48.236 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:fibaro_fgd211_02_001
2018-08-27 09:12:48.238 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:merten_507001_00_000
2018-08-27 09:12:48.239 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:heiman_hs2skz_00_000
2018-08-27 09:12:48.241 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_dwzwave2_00_000
2018-08-27 09:12:48.243 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:eco_dwzwave2_00_000
2018-08-27 09:12:48.245 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zs5101_00_000
2018-08-27 09:12:48.247 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zs5101_00_000
2018-08-27 09:12:48.249 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:shenzhen_motionsensor_00_000
2018-08-27 09:12:48.251 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:remotec_adt8021_00_000
2018-08-27 09:12:48.253 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_123580_00_000
2018-08-27 09:12:48.255 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:leviton_dzr15_00_000
2018-08-27 09:12:48.257 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:popp_009501_01_002
2018-08-27 09:12:48.259 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhla_00_000
2018-08-27 09:12:48.261 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_wadwaz1_00_000
2018-08-27 09:12:48.263 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh7_00_000
2018-08-27 09:12:48.264 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh7_00_000
2018-08-27 09:12:48.266 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1702_00_000
2018-08-27 09:12:48.268 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vision_zm1702_00_000
2018-08-27 09:12:48.270 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:intermatic_ha02_00_000
2018-08-27 09:12:48.272 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:qubino_zmnhca_00_000
2018-08-27 09:12:48.274 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_007
2018-08-27 09:12:48.276 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_007
2018-08-27 09:12:48.278 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_007
2018-08-27 09:12:48.280 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw100_01_007
2018-08-27 09:12:48.282 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:mcohome_mh10pm25_00_000
2018-08-27 09:12:48.285 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:act_zdp200_00_000
2018-08-27 09:12:48.286 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw078_00_000
2018-08-27 09:12:48.288 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw078_00_000
2018-08-27 09:12:48.290 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw078_00_000
2018-08-27 09:12:48.292 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an157_00_000
2018-08-27 09:12:48.293 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:everspring_an157_00_000
2018-08-27 09:12:48.295 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:homeseer_hsws100_00_000
2018-08-27 09:12:48.297 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:linear_pd300z2_00_000
2018-08-27 09:12:48.298 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw080_00_000
2018-08-27 09:12:48.300 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw080_00_000
2018-08-27 09:12:48.302 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw080_00_000
2018-08-27 09:12:48.304 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:vda_dimmer3_00_000
2018-08-27 09:12:48.306 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw074_00_000
2018-08-27 09:12:48.307 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw074_00_000
2018-08-27 09:12:48.309 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_zw074_00_000
2018-08-27 09:12:48.311 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:zipato_zp3102_00_000
2018-08-27 09:12:48.313 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:aeon_dsa38_00_000
2018-08-27 09:12:48.314 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:isurpass_smokedetector_00_000
2018-08-27 09:12:48.316 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:rcs_tz45_00_000
2018-08-27 09:12:48.318 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:innovus_smartpower_00_000
2018-08-27 09:12:48.319 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Checking zwave:innovus_smartpower_00_000
2018-08-27 09:12:48.323 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2018-08-27 09:12:48.326 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start inclusion - mode 2
2018-08-27 09:12:48.330 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-08-27 09:12:48.333 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
2018-08-27 09:12:48.333 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A C1 01 70
2018-08-27 09:12:48.350 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 01 00 00 B2
2018-08-27 09:12:48.352 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_ack changed from 16 to 17
2018-08-27 09:12:48.356 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-08-27 09:12:48.363 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_sof changed from 18 to 19
2018-08-27 09:12:48.364 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 01 00 00 B2
2018-08-27 09:12:48.368 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
2018-08-27 09:12:48.372 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2018-08-27 09:12:48.376 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01
2018-08-27 09:12:48.376 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@1a40a3a
2018-08-27 09:12:48.379 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 01 00 00
2018-08-27 09:12:48.383 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2018-08-27 09:12:48.385 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-08-27 09:12:48.386 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 51ms/151ms.
2018-08-27 09:13:09.171 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 4A 01 02 03 0B 04 20 01 30 31 80 84 70 85 72 86 8D
2018-08-27 09:13:09.173 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_sof changed from 19 to 20
2018-08-27 09:13:09.181 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-08-27 09:13:09.193 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_sof changed from 20 to 21
2018-08-27 09:13:09.197 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 4A 01 03 03 0B 04 20 01 30 31 80 84 70 85 72 86 8C
2018-08-27 09:13:09.203 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 12 00 4A 01 02 03 0B 04 20 01 30 31 80 84 70 85 72 86 8D
2018-08-27 09:13:09.208 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 02 03 0B 04 20 01 30 31 80 84 70 85 72 86
2018-08-27 09:13:09.215 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01
2018-08-27 09:13:09.220 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 02 03 0B 04 20 01 30 31 80 84 70 85 72 86
2018-08-27 09:13:09.224 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2018-08-27 09:13:09.232 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-08-27 09:13:09.235 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-08-27 09:13:09.245 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 12 00 4A 01 03 03 0B 04 20 01 30 31 80 84 70 85 72 86 8C
2018-08-27 09:13:09.249 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 03 03 0B 04 20 01 30 31 80 84 70 85 72 86
2018-08-27 09:13:09.253 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2018-08-27 09:13:09.256 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveInclusionEvent
2018-08-27 09:13:09.261 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-08-27 09:13:09.261 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2018-08-27 09:13:09.262 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
2018-08-27 09:13:09.265 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 3: Including node.
2018-08-27 09:13:09.266 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4
2018-08-27 09:13:09.268 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 3: Newly included node already exists - not initialising.
2018-08-27 09:13:09.272 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=C1 01
2018-08-27 09:13:09.277 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 03 03 0B 04 20 01 30 31 80 84 70 85 72 86
2018-08-27 09:13:09.279 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2018-08-27 09:13:09.283 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-08-27 09:13:09.285 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_ack changed from 17 to 18
2018-08-27 09:13:09.291 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 19ms/151ms.
2018-08-27 09:13:09.328 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 03 00 B6
2018-08-27 09:13:09.328 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_sof changed from 21 to 22
2018-08-27 09:13:09.330 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-08-27 09:13:09.337 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 03 00 B6
2018-08-27 09:13:09.340 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 03 00
2018-08-27 09:13:09.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2018-08-27 09:13:09.347 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovered
2018-08-27 09:13:09.352 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveInclusionEvent
2018-08-27 09:13:09.354 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@105314b
2018-08-27 09:13:09.357 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 3: Newly included node already initialising at MANUFACTURER
2018-08-27 09:13:09.360 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01
2018-08-27 09:13:09.362 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 03 00
2018-08-27 09:13:09.364 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2018-08-27 09:13:09.365 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-08-27 09:13:16.270 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2018-08-27 09:13:16.276 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2018-08-27 09:13:16.276 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-08-27 09:13:16.280 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller end inclusion
2018-08-27 09:13:16.282 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 01 B4
2018-08-27 09:13:16.300 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_ack changed from 18 to 19
2018-08-27 09:13:16.341 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 01 06 03 00 B6
2018-08-27 09:13:16.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-08-27 09:13:16.350 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 4A 01 06 03 00 B6
2018-08-27 09:13:16.352 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 03 00
2018-08-27 09:13:16.357 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2018-08-27 09:13:16.358 [vent.ItemStateChangedEvent] - zwave_serial_zstick_e029b827_serial_sof changed from 22 to 23
2018-08-27 09:13:16.361 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovered
2018-08-27 09:13:16.366 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveInclusionEvent
2018-08-27 09:13:16.367 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 3: Newly included node already initialising at MANUFACTURER
2018-08-27 09:13:16.369 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=05 01
2018-08-27 09:13:16.371 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=AddNodeToNetwork[0x4A], type=Request[0x00], priority=High, dest=255, callback=0, payload=01 06 03 00
2018-08-27 09:13:16.367 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@163f57e
2018-08-27 09:13:16.372 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=AddNodeToNetwork, callback id=0, expected=AddNodeToNetwork, cancelled=false        transaction complete!
2018-08-27 09:13:16.374 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-08-27 09:13:16.375 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 90ms/151ms.
