Hi All.
i have cam to a wall. i have info that comes from my Raspberry pi via node red sent with mqtt.
the values need to be divided for huamen reading. and som persentage calculations.
i am not sure where to start ? is there documents that can help me to do it ?
will it be rule base or transformation. ?
example of some calcs that needs to be done .
i will have a look at how to do it at the source. as i only used node red . as a simple interface betwoon the db and my OpenHAB server. with basic send temp to mqtt and the pi’s gpio. now i want to do some more integrated stuff. will learn and break some stuff to get it up and running.
