Hi there,
I’m just fiddling around with ExecBundle to get some stuff out from console commands.
Now I have an .items file which looks like this:
String HealthCPUTemperatur "CPU Temperatur [JSONPATH($.cpu):%s °C]" {channel="exec:command:pi_health:output"}
DateTime HealthLastExecution "Zuletzt ausgeführt [%1$tH:%1$tM:%1$tS]" {channel="exec:command:pi_health:lastexecution"}
Number VirtLalaTemperature "Temperature [%.1f °C]"
and a rule which updates the VirtLalaTemperature.
Everything is loaded fine but the “VirtLalaTemperature” is not shown on the Control Panel.
When I connect a channel it appears but then the rule result is immediately overwritten by the actual channel output. .
So my question is: How can I make the item appear when there is no channel attached ?
I only want to update it via rule so there is no need to attach a channel here. From the examples I found so far, that should work out of the box. But it isn’t.
Thank you.
