I ordered a conbee2 USB dongle recently and tried to install it by following the installation guide on the website http://phoscon.de/en/conbee2/install#raspbian via SSH. After that I installed deCONZ in Paper UI and than run into issues. I have no idea what is the next steps
"After the installation deCONZ can be started via the application menu.
Menu > Programming > deCONZ"
If I boot my Pi and plug a screen into HDMI, there is no user interface, just the common SSH surface. So I cannot follow the next steps as described on the website. I googled different installation guidings for the conbee2 but I am totaly confused now.
I tried to install the Binding Dresden Elektronik Deconz and tried to localize any device. Nothing found
Tried to find the device by following the link http://dresden-elektronik.de/pwa/login.html but nothing found.
Then you already have the best solution for your sensors.
Du you also use the HUE binding for getting the statuses of the lights?
groups/ commands has to be sent through the http binding though.
