Hello everybody. A few days ago that every so often in my logs appears this:
[WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
I have reviewed all the widgets but I cannot identify which widget is causing me problems. Is there a way?
Thanks!
rossko57
(Rossko57)
#3
looks like the result of some expression. So you could look at widgets that address Item states other than by constants.
After re-reading all the widgets, I discovered that an item was not defined in the music widget, in addition to other errors. Thanks.
