I am in the process of switching from OH1 to OH2. So far so good. While reworking rules and such, I found that there is a new Ebusd version that has in build MQTT support. Great for me, this reduces a lot of overhead compared to my “old” way of transmitting data from Ebus to OH.
What works:
OH2 in general, incl. MQTT messages that are sent and received
Ebusd in general. It understands the messages from my heating system and sends them via MQTT
Bringing the messages into OH2 String Items
What I am gloriously failing at is:
Parsing the contents of these String Items into separate Items that make sense. I can tell Ebusd to send the messages in two variants:
Ebusd MQTT output variant 1 - colon separated string (taken from Mosquitto subscription in verbose):
WP/ehp/SourceTempInput 10.38;ok
leading to the Karaf Log entry:
UG_HZ_SourceTempInput_IN changed from 10.56;ok to 10.50;ok
Ebusd MQTT output variant 2 - JSON string (taken from Mosquitto subscription in verbose):
I think you need the JsonPath transformation for this.
I use it for the following. I have an item with this value “mqtt_PhoneKris_PositionRaw changed from NULL to {”_type":“location”,“tid”:“12”,“acc”:52,“batt”:93,“conn”:“w”,“lat”:50.8993193,“lon”:5.4414403,“t”:“c”,“tst”:1508683525}"
And I transform it to multiple items using this rule:
rule "Locatie Kris berekenen"
Item mqtt_PhoneKris_PositionRaw changed
val String json = (mqtt_PhoneKris_PositionRaw.state as StringType).toString
val String type = transform("JSONPATH", "$._type", json)
if (type == "location") {
val String lat = transform("JSONPATH", "$.lat", json)
val String lon = transform("JSONPATH", "$.lon", json)
val String acc = transform("JSONPATH", "$.acc", json)
val String batt = transform("JSONPATH", "$.batt", json)
mqtt_PhoneKris_Latitude.postUpdate(lat)
mqtt_PhoneKris_Longitude.postUpdate(lon)
mqtt_PhoneKris_Location.postUpdate(lat + "," + lon)
mqtt_PhoneKris_Accuracy.postUpdate(acc)
mqtt_PhoneKris_Battery.postUpdate(batt)
mqtt_PhoneKris_LastUpdate.postUpdate(new DateTimeType())
thanks for the input, after some fiddeling it works. I got some errors in the Karaf Log stating that the “state” of my item is NULL. It was resolved by changing the JSON “filter” term to the right one (here: $.temp.value)
