(Solved) Hue emulation no device discovered
hello, im writing this cause i run out of ideas, im using openhab 2.5.4, i did setup hue emulation, installed nginx and configured it, im using alexa.amazon.com to discover my devices, i used also alexa mobile app, i enabled pairing, i tagged my items, i could find any devices..i attached below photos for my setup, please help..what else i can do
2020-08-27 20:39:19.642 [DEBUG] [ulation.internal.HueEmulationService] - REST request GET status
2020-08-27 20:39:19.653 [DEBUG] [ulation.internal.HueEmulationService] - REST response: <html><body><h1>Self test</h1><p>To access any links you need be in pairing mode!</p><p>Pairing mode: Off (V2) <a href='http://192.168.0.10:80/api/status/link'>Enable</a> | <a href='http://192.168.0.10:80/api/status/link?V1=true'>Enable with bridge V1 emulation</a></p>14 published lights (see <a href='http://192.168.0.10:80/api/testuser/lights'>http://192.168.0.10:80/api/testuser/lights</a>)<br>118 published sensors (see <a href='http://192.168.0.10:80/api/testuser/sensors'>http://192.168.0.10:80/api/testuser/sensors</a>)<br><h2>UPnP discovery test</h2><p>success</p><table style='border:1px solid black'><tr><td>serial no</td><td>name</td></tr><tr><td>null</td><td>DCS-931L(192.168.0.12:80)</td></tr>
<tr><td>1.0</td><td>TL-WR840N</td></tr>
<tr><td>427E7FAAF9AF</td><td>openHAB Hue Emulation (192.168.0.10)</td></tr>
<tr><td>105</td><td>DIR-853/ET</td></tr></table><h2>Reachability test</h2><table style='border:1px solid black'><tr><td>URL</td><td>Responds?</td><td>Ours?</td></tr><tr><td>http://192.168.0.10:80/description.xml</td><td>yes</td><td>yes</td></tr>
<tr><td>http://192.168.0.10/description.xml</td><td>yes</td><td>yes</td></tr></table><h2>Users</h2><ul><li>testuser <b>On-the-go-user#openhab</b> <small>2020-08-27T20:16:28.82</small></ul></body></html>
2020-08-27 20:39:20.258 [DEBUG] [ulation.internal.HueEmulationService] - REST request GET status
2020-08-27 20:39:20.266 [DEBUG] [ulation.internal.HueEmulationService] - REST response: <html><body><h1>Self test</h1><p>To access any links you need be in pairing mode!</p><p>Pairing mode: Off (V2) <a href='http://192.168.0.10:80/api/status/link'>Enable</a> | <a href='http://192.168.0.10:80/api/status/link?V1=true'>Enable with bridge V1 emulation</a></p>14 published lights (see <a href='http://192.168.0.10:80/api/testuser/lights'>http://192.168.0.10:80/api/testuser/lights</a>)<br>118 published sensors (see <a href='http://192.168.0.10:80/api/testuser/sensors'>http://192.168.0.10:80/api/testuser/sensors</a>)<br><h2>UPnP discovery test</h2><p>success</p><table style='border:1px solid black'><tr><td>serial no</td><td>name</td></tr><tr><td>null</td><td>DCS-931L(192.168.0.12:80)</td></tr>
2020-08-27 20:39:21.839 [INFO ] [io.hueemulation.internal.ConfigStore] - Using discovery ip 192.168.0.10
2020-08-27 20:39:21.849 [INFO ] [io.hueemulation.internal.ConfigStore] - Hue Emulation pairing enabled for 90s
2020-08-27 20:39:22.035 [DEBUG] [l.upnp.HueEmulationConfigWithRuntime] - Cannot restart thread
2020-08-27 20:39:23.615 [DEBUG] [ulation.internal.HueEmulationService] - REST request GET status
2020-08-27 20:39:23.624 [DEBUG] [ulation.internal.HueEmulationService] - REST response: <html><body><h1>Self test</h1><p>To access any links you need be in pairing mode!</p><p>Pairing mode: On (V2) <a href='http://192.168.0.10:80/api/status/link'>Enable</a> | <a href='http://192.168.0.10:80/api/status/link?V1=true'>Enable with bridge V1 emulation</a></p>14 published lights (see <a href='http://192.168.0.10:80/api/testuser/lights'>http://192.168.0.10:80/api/testuser/lights</a>)<br>118 published sensors (see <a href='http://192.168.0.10:80/api/testuser/sensors'>http://192.168.0.10:80/api/testuser/sensors</a>)<br><h2>UPnP discovery test</h2><p>upnp announcement thread not running</p><table style='border:1px solid black'><tr><td>serial no</td><td>name</td></tr><tr><td>null</td><td>DCS-931L(192.168.0.12:80)</td></tr>
2020-08-27 20:39:24.547 [DEBUG] [ulation.internal.HueEmulationService] - REST request GET status
2020-08-27 20:39:24.554 [DEBUG] [ulation.internal.HueEmulationService] - REST response: <html><body><h1>Self test</h1><p>To access any links you need be in pairing mode!</p><p>Pairing mode: On (V2) <a href='http://192.168.0.10:80/api/status/link'>Enable</a> | <a href='http://192.168.0.10:80/api/status/link?V1=true'>Enable with bridge V1 emulation</a></p>14 published lights (see <a href='http://192.168.0.10:80/api/testuser/lights'>http://192.168.0.10:80/api/testuser/lights</a>)<br>118 published sensors (see <a href='http://192.168.0.10:80/api/testuser/sensors'>http://192.168.0.10:80/api/testuser/sensors</a>)<br><h2>UPnP discovery test</h2><p>upnp announcement thread not running</p><table style='border:1px solid black'><tr><td>serial no</td><td>name</td></tr><tr><td>null</td><td>DCS-931L(192.168.0.12:80)</td></tr>
Can you update to latest openHAB? Just in case changes were made to the binding.
You did tag your items correct? They need tags like “lighting”
hi, i tired also with the latest openhab 2.5.8, same… switches tagged as “switchable”, dimmers and colors tagged as “Lighting”
I had this issue once before also. Then the binding was updated.
Not sure, can you try discovery on an actual echo device only suggestion I have. I am sure others will chime in.
i did… same issue
i was using an alexa account which is not linked to a physical amazon echo…issue resolved with amazon echo device
