Hi Community,
i’m new to Openhab, comping from FHEM. I’m trying to get my Hue Bulbs running together with a WebGui Switch and my Homematic HM-PB-2-FM. SO that every Device Knows the actual State and I’m able to Switch the light with the HM on and with the guy off.
What is the best way to get this running?
I already got the HM running together with the HM switch:
Switch ki_lights_ceiling_switch_1 "Kitchen_Button_1" { channel="homematic:HG-HM-PB-2-FM:36f880d0:NEQ0890367:1#PRESS_SHORT" }
Switch ki_lights_ceiling_switch_2 "Kitchen_Button_2" { channel="homematic:HG-HM-PB-2-FM:36f880d0:NEQ0890367:2#PRESS_SHORT" }
Switch ki_lights_ceiling_switch_1l "Kitchen Button 1 Long" { channel="homematic:HG-HM-PB-2-FM:36f880d0:NEQ0890367:1#PRESS_LONG" }
Switch ki_lights_ceiling_switch_2l "Kitchen Button 2 Long" { channel="homematic:HG-HM-PB-2-FM:36f880d0:NEQ0890367:2#PRESS_LONG" }
Dimmer KI_Light_Spot1_B "Spot 1" (g_KI_Lights_B) {channel="hue:0220:001788492029:13:brightness"}
Dimmer KI_Light_Spot2_B "Spot 2" (g_KI_Lights_B) {channel="hue:0220:001788492029:14:brightness"}
Dimmer KI_Light_Spot3_B "Spot 3" (g_KI_Lights_B) {channel="hue:0220:001788492029:15:brightness"}
Dimmer KI_Light_Spot4_B "Spot 4" (g_KI_Lights_B) {channel="hue:0220:001788492029:16:brightness"}
Dimmer KI_Light_Spot5_B "Spot 5" (g_KI_Lights_B) {channel="hue:0220:001788492029:17:brightness"}
Dimmer KI_Light_Spot6_B "Spot 6" (g_KI_Lights_B) {channel="hue:0220:001788492029:18:brightness"}
Dimmer KI_Light_Spot7_B "Spot 7" (g_KI_Lights_B) {channel="hue:0220:001788492029:19:brightness"}
Dimmer KI_Light_Spot8_B "Spot 8" (g_KI_Lights_B) {channel="hue:0220:001788492029:20:brightness"}
Dimmer KI_Light_Spot9_B "Spot 9" (g_KI_Lights_B) {channel="hue:0220:001788492029:22:brightness"}
Dimmer KI_Light_Spot10_B "Spot 10" (g_KI_Lights_B) {channel="hue:0220:001788492029:23:brightness"}
rule "KI_Lights_Switch_on"
Item ki_lights_ceiling_switch_1 changed from OFF to ON
sendCommand(g_KI_Lights_B,100)
rule "KI_Lights_Switch_off"
Item ki_lights_ceiling_switch_2 changed from OFF to ON
g_KI_Lights.sendCommand(OFF)
Am I on the right way? How could I integrate a Web Switch on the Website / in the app?
thy!
