[SOLVED] HUE Motion Sensor Temperature and Illuminance - no values on sitemap
I’m running OH 2.4 stable on a Raspi3. I just added my first HUE motion sensor to the system and motion detection, last_update as well as day/dark work just fine.
I added all channels PaperUI provided to my items-file, including
Number:Illuminance
Number:Temperature
Number (Battery)
Sitemap shows none of the above numbers. For Battery I get “-” and the other entries are just blank. Is there anything special I have to bear in mind?
Log shows the values and their changes.
I added the Items into a test-group and did not add them manually to sitemap.
Thanks in advance
Sven
Can you post the actual Item definitions you used? You may need string formatters (%d, %f) and units in the Item definition, e..g
Number:Temperature hueTemp "Temp %.1f %unit%" {channel="hue..."}
that will give you a floating point value with 1 decimal place, and the default unit sent by the binding.
Number:Temperature      Temperatur     "Temperatur"         <temperature>     (gSensoren, gTest)    { channel="hue:0302:001788207687:27:temperature" }
Number:Illuminance      Helligkeit     " Helligkeit"          (gSensoren, gTest)    { channel="hue:0106:001788207687:29:illuminance" }
Hope this helps
Ok, try the following instead (and watch the logs to see what the items are updated to)
Number:Temperature Temperatur "Temperatur %.1f %unit%" <temperature> (gSensoren, gTest) { channel="hue:0302:001788207687:27:temperature" }
Number:Illuminance Helligkeit " Helligkeit %d %unit%" (gSensoren, gTest) { channel="hue:0106:001788207687:29:illuminance" }
That was it! Thanks a lot!
