RPi, OpenHABian.
I have created three sitemaps
home.sitemap
misc.sitemap,
notifications.sitemap
in the sitemaps folder
but basicUI and classicUI will only accept home.sitemap.
Working with the BasicUI:
(1) I tried adding ?sitemap=notifications to the localhost…URL.
Result: I get a page saying, “Welcome…Available sitemaps ! Home”. If I click Home, I get the home.sitemap.
(2) I have tried renaming home.sitemap to home.sitemapX to “hide” it.
Result: BasicUI says I have not defined any sitemaps yet. But the other two are in the sitemaps folder where home.sitemap is located.
(3) I have edited PaperUI,configuration, services and changed the default sitemap to notifications and misc and neither work.
Result: I get the “have not defined” message for either.
(4) I have created basicui.cfg and inserted:
# Defining the default sitemap to use
org.eclipse.smarthome.basicui:defaultSitemap=notifications
# The icon type to use, either png or svg
org.eclipse.smarthome.basicui:iconType=svg
Result: Again I get the undefined.
(5) If I remove “X” from home.sitemapX and start basicUI
Result: I get the not defined (because of either the cfg or the default in PaperUI) but if I add ?sitemap=home I get the home.sitemap.
For the ClassicUI
For step (1) above I get a large dump starting with "Problem accessing /classicui/app: Reason Server Error Caused By followed by 30 or 40 lines with a whole lot of references to jetty but including “sitemap notifications could not be found”.
Then more Caused By and similar lines then more Caused By and similar lines.
But I can change the URL to …sitemap=home and I get the home.sitemap but notifications.sitemap is in the same folder as home.sitemap.
For step 2 above I get the same large dump.
For step 3 above I get the large dump.
I didn’t try the equivilant of step 4 for the ClassicUI because I’m pretty sure I’ll get the similar results.
For step 5 above I get the large dump but again can replace the “sitemap=notifications” with “sitemap=home” and I get the home sitemap.
I have rebooted many times during these steps.
What can I do to change the site map? I have a lot of experimentation to do and really need to swap sitemaps repeatedly. Also, I have a HABpanel and that seems to ignore these sitemaps but perhaps it is locking things up…perhaps???
Any ideas?
