2021-04-29 20:35:42.630 [ERROR] [lipse.smarthome.io.net.exec.ExecUtil] - couldn't execute commandLine 'C:/openHAB2/conf/scripts/ledfx.sh'
java.io.IOException: Cannot run program "C:/openHAB2/conf/scripts/ledfx.sh": CreateProcess error=193, %1 is not a valid Win32 application
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1128) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?]
at java.lang.Runtime.exec(Runtime.java:592) ~[?:?]
at java.lang.Runtime.exec(Runtime.java:416) ~[?:?]
at java.lang.Runtime.exec(Runtime.java:313) ~[?:?]
at org.eclipse.smarthome.io.net.exec.ExecUtil.executeCommandLine(ExecUtil.java:63) [bundleFile:?]
at org.eclipse.smarthome.model.script.actions.Exec.executeCommandLine(Exec.java:42) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor663.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1175) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1150) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1136) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) [bundleFile:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) [bundleFile:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) [bundleFile:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) [bundleFile:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:81) [bundleFile:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:313) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.io.IOException: CreateProcess error=193, %1 is not a valid Win32 application
at java.lang.ProcessImpl.create(Native Method) ~[?:?]
at java.lang.ProcessImpl.<init>(ProcessImpl.java:478) ~[?:?]
at java.lang.ProcessImpl.start(ProcessImpl.java:154) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1107) ~[?:?]
Call curl directly without the script. The logfile tells you the problem. It has problems running the .sh as a process. Search curl here in the forum. There should be examples
Ok. Why don’t you call the curl command directly? By using the Linux like bash script, you now also need to install e.g. git on your machine. That does not make sense imho
Did not bother me to install git on the computer,
Which I also tried to put the curl command directly but failed
I have no prior knowledge with curl and exec commends
