Sorry for asking (I hope questions is sort of welcomed in this forum)
I have surfed a little around but what I could find is that there is a default user and password for the Samba share on a newly installed RPI installation. But hm when it doesn’t answer when Browsing from my PC with \ip-adress\ then I wonder what do I miss? I see that it should be setup in the configuration tool as option 66 but where do I find option 66 in the configuration tool? Or is it option 67 ?
Platform information:
Hardware: RPI 3b+
openHAB version: The lastes OpenHabian version
Issue of the topic: Samba Share on a fresh install
The shares are configured to be not open for guests nor to the public. Let's activate the "openhab" user as a samba user and set his password (e.g. "habopen"):
sudo smbpasswd -a openhab
It might be that you have not set a username and password for the share.
Thanks but there is no windows credentials saved for samba login. What I really can’t figure out is that I usual never have problems connecting to shares. For me it seems like the service is not started or configured in OpenHabian latest version RPI install. I have now moved from HassIO to OpenHab and I’m struggling with fundamental things that I didn’t expect - I have setup samba shares on RPI before (I will figure it out again if it necessary) but then I would have expected that it was on the “to-do-list” of setting up a new OpenHab installation and that I didn’t see or maybe I have missed some documents.
Have now tried reinstalling Samba Share and now I found samba setup option 66 in openhabian-config - couldn’t see the option due to resolution of putty screen. But it did not do any difference - I can see that /etc/samba/smb.conf is updated with OpenHab setup.
I pressed: sudo service smbd restart afterwards but still I cannot get in contact with my Samba share.
In Windows 10 the SMB is disabled on windows updates, evertime windows does an update it appears it disables the old SMB sharing optionand you loose the access to the SMB Shares via windows 10.
You Need to re enable SMB V1 in windows
Follow this link shows how to re enable SMB v1
