[Solved] iCloud Presence Turn on outside light
Ok I wrote a rule to turn on outside light when sunset occurred. then I was like I can make this better, what if the light turned on when I was like on the road I lived on, and I thought I had figured out how to do that. but I’ve run into a snag, hoping you guys can help… here’s the rules for those two things, I have two issues, one is it doesn’t turn on in time, I may have fixed that, but the main thing is it keeps turning on… I turn it off 5 minutes later it’s back on… UGH!
I think I need another variable so I can tell OH2 that I’m already home, I just can’t wrap my brain around how to do that…
Thanks for your help
1st rule
var boolean sunset = false
rule "Sunset rule"
        Channel 'astro:sun:local:set#event' triggered START
        sunset = true
        if (Chase_iPhone_Home=="ON" || Tracy_iPhone_Home=="ON" || Cale_iPhone_Home=="ON")
        sendCommand(PorchLight, ON)
        sendCommand(LED_Power,ON)
        Light_Color.sendCommand("1,0,100") // White
2nd rule
rule "Chase_iPhone Home"
    Item Chase_iPhone_Location changed
        // specify your home location 1.000 lat 2000 long
// Didn't want any of you guys seeing where I actually live :slight_smile:
        val PointType home_location  = new PointType(new DecimalType(1.0000), new DecimalType(2.000))
        val PointType phone_location = Chase_iPhone_Location.state as PointType
        val int distance = phone_location.distanceFrom(home_location).intValue()
        // specify your preferred radius (in meters)
        if ( distance < 1000)
                Chase_iPhone_Home.postUpdate(ON)
                logInfo("iPhone Home", "Chase's iPhone is at home.")
                if (sunset == true)
        else
                Chase_iPhone_Home.postUpdate(OFF)
                logInfo("iPhone Home", "Chase's iPhone is away.")
you’re probably querrying your distance from Home, using the iCloud Binding for every 5min.
As a result in “2nd rule” Then your Item
Chase_iPhone_Home is getting updated, which results in PorchLight and LED_Power Items being turned on each 5min. So congrats: Your rule works, as expected :wink:
The way I have implemented it, is to create a dummy item switch (Presence) which gets turned on when the phones are within a distance.
Then, you could do something like
rule "Lights on"
when Item Presence changed from OFF to ON
Light_Color.sendCommand(“1,0,100”) // White
this way, your lights only get turned on once, when the Switch “Presence” gets turned on.
Kurt
First off all, please use code fences.
The delay is caused by the binding. You can force the refresh to get the actual location.
There are two ways to prevent the rule turning the light on again. I suggest, 5 minutes is the refresh time of the iCloud binding. So your second rule also turns on the light every 5 minutes. So you can either split the rule in two or change your existing rule a little bit:
rule “Chase_iPhone Home”
// Didn’t want any of you guys seeing where I actually live :slight_smile:
if ( distance < 1000) {
     if(Chase_iPhone_Home != ON){
         logInfo(“iPhone Home”, “Chase’s iPhone is at home.”)
         if (sunset == true){
else
logInfo(“iPhone Home”, “Chase’s iPhone is away.”)
or two rules
if ( distance < 1000){
} else {
rule “Chase_iPhone Home Lights on”
Item Chase_iPhone_Home changed to ON
Thanks! I like this idea.
Thanks for the code fences, I had no idea, I always thought the website did that automatically… my bad… :blush: I did go back and put them in now. And thank you for all the detail, I’m still very new to OH2.
ok maybe I need a little more help, so what I did was, I already had a dummy switch ( Chase_iPhone_Home) is the switch, in the code
I change the previous to this.
rule "Sunset rule"
        sunset = true
and put this in there…
but this is all Jacked up! can you pass along a little more wisdom? yes I know it’s commented out, that was to get rid of the error messages in my rules file.
        val PointType home_location  = new PointType(new DecimalType(1.0000), new DecimalType(-2.0000))
        else
//rule "Turn On lights"
//when
//      Item Chase_iPhone_Home change from OFF to ON or
//      Item Tracy_iPhone_Home change from OFF to ON or
//      Item Cale_iPhone_Home change from OFF to ON
//then
//        sendCommand(PorchLight, ON)
//        sendCommand(LED_Power,ON)
//        Light_Color.sendCommand("1,0,100") // White
//end
In your last rule there is missing
    if (sunset == true)
before the brackets (if you still want to turn lights on only after sunset, else remove the{})
I overlooked it first: it has to be changed and not change
Besides that it is a good idea to make a Switch item for your sunset instead of using a var.
Thanks SO MUCH! I made those changes, and I’ll see how it goes tonight! I will not call myself a programmer, cause I’m not, but I do write scripts to do a lot of admin stuff, why is having a dummy switch better than a variable? that seems weird to me?
To understand the advantages have a look at this example: Design Pattern: Simple State Machine (e.g. Time Of Day)
A big advantage having an item is also that you can persist it, restore it on startup and it holds the state even when you rewrite and reload your rule after sunset.
In addition to persistence and restore on startup, there are a lot of IMHO even more compelling reasons to use an Item instead of a variable for something like time of day.
Variables can only be used in that one rules file. Items can be access from anywhere. You will likely have lots of rules across many files that will want to know the time of day.
Variables cannot be displayed on a sitemap or Habpanel. Items can. This can be useful information for users of your home automation.
Variables cannot be queried for through the REST API. Items can. External services may care about timer off day too (e.g. Tasker on Android phones).
Variables cannot be used to trigger rules. Items can. You may want to do things when the time of day transitions to a new time period.
By using an Item you only need one rule to calculate timer off day in one place and should you choose to modify how you calculate the time of day (e.g. use a different Astro trigger) you only have to change it on one place. With a variable you have to change it in each rules file that cares about that time if day.
I’m starting to think I’m an idiot… I can’t even get this code to work…
where am I going wrong?
rule "Init"
        System started
        sunset = false
rule "Sunset rule"
        sunset = true
        Item Chase_iPhone_Home changed from OFF to ON or
        Item Tracy_iPhone_Home changed from OFF to ON or
        Item Cale_iPhone_Home changed from OFF to ON
        if (sunset == true)
        val PointType home_location  = new PointType(new DecimalType(1.0000000), new DecimalType(-2.000000))
        else
You forgot to declare your var sunset at the top of the file.
I put it in the items file as a switch…
then the correct syntax would be (assuming sunset is your Switch item)
rule "Sunset rule"
        sunset.postUpdate(ON)
and
        if (sunset.state == ON)
oh! that make total sense now… Thanks Syn!
Just want to throw this out here for anyone who looks at this in the future, I’m still playing with the distance part, currently I’m up to 5000 (in Meters) and it still not seeing me home in time to turn the light on in time. :frowning:
I’m guessing that because the icloud binding only updates every 5 minutes, I’ll need it to be like somewhere about 10 minutes away to make sure it turns on before I arrive… trying 15000 meters tomorrow.
        else
Or you combine multiple events to get a better presence detection, e.g. (because it uses the force refresh command of the iCloud binding) https://community.openhab.org/t/icloud-device-data-integration-in-openhab/32329/298?u=syn
Browse the forum, there are tons of examples and suggestions how to do that.
One last note, none of my rules that had switches were working and I could not figure out for the life of me why… so just in case someone else comes across this… you have to have switches with .state on the end of them like this
Incorrect at least on my openhab box
if (sunset == ON)
Correct
