I have an ID Lock 150 Z-Wave through the Aeon Z-Stick Gen5.
The lock can have up to 9 RFID keys and 9 PIN Codes registered.
I want to know which key was used to unlock the door, so I am looking at the logging output from the Raw Alarm (JSON) channel.
When the lock is opened using a PIN code I see:
{"notification":"ACCESS_CONTROL__KEYPAD_UNLOCK","code":"1","level":"0","type":"ACCESS_CONTROL","event":"6","status":"255"}
The code property tells me which PIN-code was used.
But when the lock is opened using a RFID key all I see is:
{"notification":"ACCESS_CONTROL__REMOTE_UNLOCK","level":"0","type":"ACCESS_CONTROL","event":"4","status":"255"}
which is always the same regardless of which RFID key was used.
The ID Lock 150 User Reference Manual section 4.3 says that both Keypad Unlock and RF Unlock sends a parameter with the key used, so I guess this could be included in the unlock event too.
But… I have zero experience with OpenHAB, just installed it today. And when I try to figure were the source code for this is to be found I am at loss. There is no Z-Wave code in openhab/openhab2-addons as far as I can see?
If someone could point me in the right direction I am sure this would be a simple PR…
Thanks,
/jesper
