[SOLVED] If item state then rule
  • Platform information:
    • Hardware: raspberry pi 3b
    • OS: openhabian
    • openHAB version: 2.3.0
  • Issue of the topic: I need a rule, where openhab switches the item “relay8” OFF, when item io1 and io2 are both OFF. I tried so many ways but I don’t figure it out how that simple rule sould work…
    Important for me is that the rule checks the states and don’t waits for an event of both things..
Can you help me or send me a sample rule for that?
p.s: i read many of the articles in here…
THANK YOU :slight_smile:
rule "simple switch check"
    Item io1 changed or
    Item io2 changed
    if (io1.state == OFF && io2.state == OFF) {
        relay8.sendCommand(OFF)
The rule will trigger everytime io1 or io2 changes
Then the rule checks if the state (.state) of io1 AND (&&) the state (.state) of io2 are both EQUAL (==) to OFF
Then if that condition is true then rule will send an OFF command (.sendCommand(OFF)) to relay8
Does that make sense?
Thank you! That really makes sense and it works perfectly :slight_smile:
Does the .state and && commands just work in a if-condition?
You need to start reading the documentation…
I gave you the rule snippet as an example but we are not here to write code for you.
You need to read the docs and have a go a it. If your code doesn’t work, read the docs again. If it still doesn’t work look in the forum. And then ask for help.
Welcome to OH
https://www.openhab.org/docs/tutorial/rules.html
