[Solved] Inbox empty - openhab 2.0
Installation of openhab beta5 > works fine and inbox got filled with new things identified, e.g. hue
Installation of openhab 2.0 > inbox empty and does NOT fill, e.g. identify hue, etc..
Is this normal behaviour of version 2.0?
Have done both, oh2 beta5 and oh2 2.0 installation on same hw/sw environment with following manual installation procedure:
for oh2 beta5:
wget Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog
oh2 2.0.0
wget -O openhab-download.zip Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog
Got it! Once dedicated bindings are installed manually, inbox gets filled with things automatically :wink:
Hi Jens. I’m an absolute newbie in the OpenHab world :slight_smile: I Have a Problem with my Wemo Switches. On the Paper UI, I Installed the Wemo Add On, but only one of my three switches appeared in my Inbox.
How do I get the other two Wemo Switches?
What type of WeMo devices is missing ?
Are those in the same network like the discovered ones?
You should start a seperate discussion for your issue, tagging as WeMo related.
Hello Hans-Jörg.
Thanks for your quick reply.
I’ve got three Wemo Switches:
http://www.belkin.com/de/F7C027-Belkin/p/P-F7C027;jsessionid=8AA942C28DE54BFB6CD1712326A206C2/
They are all in the same network, but only one of my three equal switches appeared in my Inbox.
But as you suggested, I will start a seperate discussion about those switches. Thank you!!
Greetings, Daniel (Germany, Bavaria)
