Seeking help after several attempts to add a DANALOCK to openhab2 (using z-wave). The lock will include and is recognized, but no commands are accepted.
Actions:
Excluded (to be sure); Included; Added as thing; Added items; Triggered inclusion from device only; Restarted Openhab; Re-included (without excluding); Restarted Openhab.
Problem:
In no situation after adding items, the lock shows any response to the switch. the battery level is available.
No XML is created in /var/lib/openhab2/zwave for the device
Using
Z-wave library 2.2.0 snapshot (from source dated 2017-09-04; installed in addons)
Openhab 2.1.0-1
BTZW125 Danalock V2 circle
Manufacturer: 010e “Poly-control”
Type/ID: 0009:0002
Firmware Version: 0.0
Z-Wave Plus Node Type: UNKNOWN_TYPE
Basic Class: ROUTING_SLAVE
Generic Class: ENTRY_CONTROL
Specific Class: SECURE_KEYPAD_DOOR_LOCK
Using Security: ?
Listening: X
Routing, Frequently Listening, Beaming: V
Log level on trace.
NODE 41: ZWaveSecurityCommandClass in verifyAndAdvanceState with newstep=SECURITY_NONCE_GET, currentstep=SECURITY_NETWORK_KEY_SET
NODE 41: payload bytes for incoming security message=00 29 02 98 40
NODE 41: Received SECURITY_NONCE_GET
NODE 41: SECURITY_ERROR Device message contained nonce that is unknown to us, id=-20.
After inclusion ends:
NODE 41: Timeout while sending message. Requeueing - 0 attempts left!
NODE 41: Handling failed message.
NODE 41: Got an error while sending data. Resending message.
NODE 41: Too many retries. Discarding message: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=41, callback=86, payload=29 …
And:
NODE 41: SECURITY_ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
Some help is appreciated.
