Hello guys,
I have a problem with data in my Influx database. Last entry for all items in database is “delayed” for about 9 hours. Let say now is 2018-06-18 18:15 and last temperature entry in database have timestamp 2018-06-18T09:15:00.138Z 26.7 and the latest value in Grafana have timestamp 2018-06-18 11:21. Is this normal behavour ? Is it possible to collect and display data for, let say, last hour and older ? My persistence file is:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
Items {
Fan_switch : strategy = everyChange
Sensor_1_temperature, Sensor_1_humidity, Sensor_1_heat_index, Sensor_1_switch_1, Sensor_1_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_2_temperature, Sensor_2_humidity, Sensor_2_heat_index, Sensor_2_switch_1, Sensor_2_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_3_temperature, Sensor_3_humidity, Sensor_3_heat_index, Sensor_3_switch_1, Sensor_3_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_4_temperature, Sensor_4_humidity, Sensor_4_heat_index, Sensor_4_switch_1, Sensor_4_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_5_temperature, Sensor_5_humidity, Sensor_5_heat_index, Sensor_5_switch_1, Sensor_5_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_6_temperature, Sensor_6_humidity, Sensor_6_heat_index, Sensor_6_switch_1, Sensor_6_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_7_temperature, Sensor_7_humidity, Sensor_7_heat_index, Sensor_7_switch_1, Sensor_7_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_8_temperature, Sensor_8_humidity, Sensor_8_heat_index, Sensor_8_switch_1, Sensor_8_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_9_temperature, Sensor_9_humidity, Sensor_9_heat_index, Sensor_9_switch_1, Sensor_9_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_10_temperature, Sensor_10_humidity, Sensor_10_heat_index, Sensor_10_switch_1, Sensor_10_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_11_temperature, Sensor_11_humidity, Sensor_11_heat_index, Sensor_11_switch_1, Sensor_11_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_12_temperature, Sensor_12_humidity, Sensor_12_heat_index, Sensor_12_switch_1, Sensor_12_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_13_temperature, Sensor_13_humidity, Sensor_13_heat_index, Sensor_13_switch_1, Sensor_13_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_14_temperature, Sensor_14_humidity, Sensor_14_heat_index, Sensor_14_switch_1, Sensor_14_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_15_temperature, Sensor_15_humidity, Sensor_15_heat_index, Sensor_15_switch_1, Sensor_15_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_16_temperature, Sensor_16_humidity, Sensor_16_heat_index, Sensor_16_switch_1, Sensor_16_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_17_temperature, Sensor_17_humidity, Sensor_17_heat_index, Sensor_17_switch_1, Sensor_17_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_18_temperature, Sensor_18_humidity, Sensor_18_heat_index, Sensor_18_switch_1, Sensor_18_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_19_temperature, Sensor_19_humidity, Sensor_19_heat_index, Sensor_19_switch_1, Sensor_19_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
Sensor_20_temperature, Sensor_20_humidity, Sensor_20_heat_index, Sensor_20_switch_1, Sensor_20_switch_2 : strategy = everyMinute, everyHour, restoreOnStartup
And Grafana dashboard looks like that:
Could somebody, please, be so kind and give me a hint what could be the reason for this ?
Regards, Peter
