Hi Everybody,
openHab 2.3 (release build) with InflufDB persistence and InfluxDB
I have the following persistence definition:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
gPersistence* : strategy=everyChange, restoreOnStartup
gSoilHumidity* : strategy=everyUpdate, restoreOnStartup
The strange thing is, all Items within the group gPersistence get persisted, but the ones in the group gSoilHumidity aren’t.
Group definitions:
Group gPersistence "Persistence"
Group gSoilHumidity "Bodenfeuchte"
And the items that are in gSoilHumidity:
Number IrrigationRaisedBedMoistureMin "min. Bodenfeuchte Hochbeet [%d %%]" <water> (gSoilHumidity)
Number IrrigationRaisedBedMoistureMax "max. Bodenfeuchte Hochbeet [%d %%]" <water> (gSoilHumidity)
Number MoistureRaisedBed "Feuchtigkeit Hochbeet [%d %%]" <water> (gSoilHumidity)
All of those items have valid values and get updated as well:
2018-08-01 18:43:55.629 [ome.event.ItemCommandEvent] - Item 'MoistureRaisedBed' received command 63
2018-08-01 18:43:55.658 [vent.ItemStateChangedEvent] - MoistureRaisedBed changed from 62 to 63
2018-08-01 18:43:55.670 [ome.event.ItemCommandEvent] - Item 'IrrigationRaisedBedMoistureMin' received command 40
2018-08-01 18:43:55.679 [ome.event.ItemCommandEvent] - Item 'IrrigationRaisedBedMoistureMax' received command 70
I’ve also tried with everyChange but it is still the same - and in the end i want to have everyUpdate since two of those items usually do not change but i want to see them as straight lines in grafana.
Does somebody have an idea why this is not working?
