As the title says, the binding was working flawlessly for past couple of months, but suddenly, OpenHAB receives updates from the Central Unit, but when it sends updates to it, the unit simply doesn’t record them. I couldn’t find anything specific in the logs… @oliver_kuhl are you familiar with such behaviour?
p.s.
the only thing that is different is that recently i updated the firmware of the central unit to latest one (1.913 - 2.1.0.55). I have 7 RSTs in my network…
I made a mistake… I’m not a beta tester of new SHC 2… i have an old one… It was working beautifully (i would say until the last update, or at least then is when i noticed that it’s not working anymore…)
So, to answer your q’s
no current version
yes, the same version i run also
it worked before
i’m using 2.4 now, but at the time of reporting the issue i was on a 2.4 snapshot version
yes, openhab is receiving updates from the api. that’s how i found out about the issue, as i set a temperature on one of RST and it received an update couple of seconds later and i noticed that the value is back to ‘old’ one… so i tried again, and same behaviour… i noticed that what openhab is ‘sending’ to central unit, is somehow being ignored or never transferred at all…
correct
i do have it for some time…
innogy-debug.log (32.7 KB) - you have both logs; from basicui and paperui… i hope that you’ll find smth in them
What is different from my working installation is that in your case the binding sends the update commands including celsius:
handleCommand called for channel 'innogysmarthome:RST:32b1b33b:6bb...f53:set_temperature' of type 'RST' with command '25 °C'
In my case it would be:
handleCommand called for channel ... of type 'RST' with command '25'
I think this has to do with units of measurements. Do you use those kind of definitions?
I do not and I don’t know, if the binding could handle those units (I never wrote any code regarding this).
@oliver_kuhl as I said, you nailed it As soon as i removed dimensions (temperature), all started to work as before… I don’t know if this should be handled somehow in future versions of the binding or not, but I’m happy you helped me fixing the issue
Yes it should. But it will take some time for me to handle it as I work on a huge update due to major API changes, that has to be done first. Thanks to report this as I didn‘t know about it before.
