Dear all,
I kindly ask your support in order to install openhab2 (the way to communicate with my Bticino plant is steep yet…).
Here some information, hope someone can help me:
Linux mint installation (Ubuntu)
Java version:
openjdk version “10.0.1” 2018-04-17
OpenJDK Runtime Environment Zulu10.2+3 (build 10.0.1+9)
OpenJDK 64-Bit Server VM Zulu10.2+3 (build 10.0.1+9, mixed mode)
I’ve installed openhab2 following the documentation but I can only arrive to “sudo /etc/init.d/openhab2 start”, after the OK I proceed wit the “status” and that is the result:
sudo /etc/init.d/openhab2 status
/var/lib/openhab2/tmp/port shutdown port file doesn’t exist. The container is not running.
I tried to go into the tmp folder but I can see only another folder called “instances” with a file “instances.proprerties”.
I also searched in the community and someone solved the problem with a new installation…I am at the 4th installation…
Thank you for a feedback!
Alessio
