[SOLVED] Integrating openhab and google assistant
Here you go:
Welcome to the openHAB world :slight_smile:
edit: I like your Log2Ram tip: Raspberry Pi OS Headless Setup - All about Automation: Home Assistant Node Red Docker API much more
Hello Dim, I have added the label and tag and tried once again to pair it with google assistant. It gets synced and an alert of “assigning room” pops out and still nothing gets added under devices in home control. Here is the json of the switch.
“link”: “http://192.168.50.30:8080/rest/items/wemo_socket_Socket_1_0_201612K003B1F9E_state”,
“state”: “NULL”,
“type”: “Switch”,
“name”: “wemo_socket_Socket_1_0_201612K003B1F9E_state”,
“label”: “Switch”,
“category”: “Switch”,
“tags”: [
“socket”
“groupNames”:
Tags are case sensitive and the available ones for the GA integration (currently) are the following:
["Lighting"]
["Switchable"]
["Scene"]
["Outlet"]
["Thermostat"]
["CurrentTemperature"]
["CurrentHumidity"]
["TargetTemperature"]
["homekit:HeatingCoolingMode"]
Try Switchable or Outlet
edit: also for the Item to work with GA, it has to receive at least 1 state update since startup
It needs to appear on openHAB Cloud - Log in before it can be used with GA
