I’m struggling to connect remotely using the iOS App through https://myopenhab.org . I have other OH instances that work perfectly but they were set up some time ago.
I can login and control everything using Chrome but not my mobile for some reason. I can see that openHAB Cloud - Log in does not contain any devices and displays the following message:
No Devices
You currently have no devices registered with openHAB Cloud. To register a new device, download the openHAB app and set https://myopenhab.org:443 as the remote URL and your openHAB Cloud login data as username and password.
There is obviously some kind of bug somewhere, anyway problem solved.
I completely deleted myopenhab.org account, removed the cloud connector and set it up from scratch using the same username and password as I did before. No luck, same problem.
I then decided to change my password to something else and it worked!
By the way if anyone thinks I’m an idiot and probably typed the wrong password or something then that is incorrect as I use a password manager and the password worked fine using a browser just not the App.
Hope this helps someone else that comes accross this issue.
