Good morning community,
finally I am a proud owner of the HM-MOD-RPI-PCB Module and after many up and downs with updating the firmeware I mananged to get it work (I was forced to install FHEM on a second SD-Card in order to use FHEM to update the Firmeware).
After I have read that homegear does not support the Homatic IP protocoll - I cannot find the post anymore
- I decided to install pivccu on my exsisting openhabian installation. To do so I did the following steps:
- Update and upgrade of openhabian
- Following the instructions of Alex Reinert on github
- Added the HmIP-STHO-A for testing
- Installation of Homatic Binding
At the beginning everything works perfect and I was dancing through our living room
but now I have an issue:
The main one is that after 12 hours openhab and pivccu suddenly wasn’t connected to the network anymore (I have checked on my fritzbox). So I was not able to see my sitemap on BaiscUI or AndroidApp. I tried a few minutes later and suddenly I was able to open the webinterface of piccu but not openhab. Half an hour later I was able to open BaiscUI again but not via AndroidAPP.
Edit: The Raspberry Pi 4 is connected via LAN and openhabian is running on it.
Is there something additionally I need to do?
Many thanks in advance and best regards
BrainPain
