[SOLVED] Issues in a rule
Hello
I’ve found this message in my logs, but I don’t understand. Can you please help me?
2025-10-23 08:37:49.525 [WARN ] [el.core.internal.ModelRepositoryImpl] - DSL model 'presence.rules' has errors, therefore ignoring it: There is no context to infer the closure's argument types from. Consider typing the arguments or put the closures into a typed context.
Here my rule:
// Global variables
var Timer cameHomeTimer = null
// Presence (Home) Unifi in
rule "Set Home"
    Member of gPhones changed to ON
    val setHome = gPhones.members.filter[ p | p.state == ON && p.name == triggeringItem.name].map[ name.replace("_Phone_Home_Unifi_online", "") ]
    switch setHome {
        case setHome.get(0) == "Axxxxx": {
            if (A_Presence.state == OFF) {
                A_Presence.sendCommand(ON)
        case setHome.get(0) == "Cxxx": {
            if (C_Presence.state == OFF) {
                C_Presence.sendCommand(ON)
        //case setHome.get(0) == "Cxxx": C_Presence.sendCommand(ON)
// Presence (Home) welcome message
rule "Welcome home my dear"
    Member of gPresence changed to ON
    if(cameHomeTimer !== null) {
        return; // do nothing if there is already a Timer
    logInfo("test", "Rule triggered by " + triggeringItem.name + " at " + now.toString)
    cameHomeTimer = createTimer(now.plusSeconds(5), [ |
        val cameHome = gPresence.members.filter[ h | h.state == ON && (h.name == triggeringItem.name || (h.lastUpdate !== null && h.lastUpdate.isAfter(now.minusSeconds(6)))) ].map[ name.replace("_Presence", "") ]
        gPresence.members.forEach[ h | logInfo("test", "Values for " + h.name + "\n" + "State = " + h.state.toString + "\n" + "LastUpdate = " + h.lastUpdate.toString)]
        var String message = "Benvenuti a casa: "
        switch(cameHome.size) {
            case 0: {
                logError("came home", "Unexpected number of phones: " + cameHome.size)
                return;
            case cameHome.size == 1 && cameHome.get(0) == "Axxxxx": message = "Benvenuto a casa, Axxxxxx"
            case cameHome.size == 1 && cameHome.get(0) == "Cxxx": message = "Benvenuta a casa, Cxxx"
            case cameHome.size == 1 && cameHome.get(0) == "Sxxx": message = "Benvenuta a casa, Sxxxx"
            case cameHome.size == 1 && cameHome.get(0) == "Exx": message = "Benvenuto a casa, Exxxxx"
            case cameHome.size == 1 && cameHome.get(0) == "Axx": message = "Welcome home, Axx"
            case cameHome.size == 1 && cameHome.get(0) == "Cxxxx": message = "Welcome home, Cxxxx"
            default: {
                message = message + cameHome.reduce[ String list, String name | list + ", " + name ]
                val ind = message.lastIndexOf(",").toString
                //message = new StringBuilder(str).replace(ind, ind+1," e").toString();
                message = message.replace(ind, " e ").toString();
        logInfo("check message", "message is: " + message)
        Echo1_TTS_Volume.sendCommand('90')
        //Echo_Living_Room_TTS.sendCommand('<speak><break time="2s"/>' + message + '</speak>')
        Echo1_TTS.sendCommand(message)
// Presence (Away) GPS out
rule "Set Away"
    Member of gPGPS changed to OFF
    val setAway = gPGPS.members.filter[ a | a.state == OFF && a.name == triggeringItem.name].map[ name.replace("_Presence_GPS", "") ]
    switch setAway {
        case setAway.get(0) == "Axxxx": A_Presence.sendCommand(OFF)
        case setAway.get(0) == "Cxxx": C_Presence.sendCommand(OFF)
thanks for helping me
Andrea
As there are three rules in the file, the first step would be to separate them (temporarily) into three files.
What do the groups look like? I don’t get the point what the code is supposed for, I mean, e.g. the first rule:
rule "Set Home"
		p.state == ON &&
    switch setHome {
why don’t do it this way?
rule "Set Home"
    val String setHome = triggeringItem.name.replace("_Phone_Home_Unifi_online", "")
    switch(setHome) {
        case "Axxxxx": if(A_Presence.state == OFF) A_Presence.sendCommand(ON)
        case "Cxxx"  : if(C_Presence.state == OFF) C_Presence.sendCommand(ON)
A closure is sometimes called a lambda and sometimes called a function. In Rules DSL any time you have [ | ] you are defining a closure.
That should help narrow down which lines of code the error is coming from.
The arguments passed to a closure are the stuff before the | which further narrows the problem down.
The specific problem, reworded in more generic terms is “I can’t figure out what these arguments are, consider telling me.” You actually do this for one of the closures.
There you are telling the language parser that list is a String and name is a String.
So you just need to do that for the other lambdas in the rule where it’s complaining.
val setHome = gPhones.members.filter[ GenericItem p | p.state == ON...
Though, as @Udo_Hartmann points out, you can likely eliminate a bunch of these closures entirely.
Thank you so much @Udo_Hartmann @rlkoshak for your example and explanation.
I’ve understood, and now I’ve fixed/optimized the rule.
thanks again
Andrea
