fronti90
(Michael)
February 10, 2020, 1:21pm
1
Platform information:
Hardware: RPi4 4GB
OS: HypriotOS (debian)
openHAB version: 2.5.1
Issue of the topic: After switching to a docker setup and updating to OH 2.5.1 and also switching from a RPi3 to RPi4 (old one broke down) all zwave things keep getting set offline and back to online. Additionally the docker container keeps running into OutOfMemory. I think the first issue is causing the OutofMemory issue (i will attach logs for that next time it happens).
Please post configurations (if applicable):
docker-compose.yml:
version: '3.7'
services:
openhab:
image: "openhab/openhab:2.5.1"
restart: always
network_mode: host
volumes:
- "/etc/localtime:/etc/localtime:ro"
- "/etc/timezone:/etc/timezone:ro"
- "/opt/openhab/addons:/openhab/addons"
- "/opt/openhab/conf:/openhab/conf"
- "/opt/openhab/userdata:/openhab/userdata"
- "/mnt/hdd/logs:/openhab/userdata/logs"
environment:
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin"
CRYPTO_POLICY: "unlimited"
devices:
- "/dev/serial/by-id/usb-Silicon_Labs_Qivicon_ZigBee_Device_05000678-if00-port0:/dev/ttyUSB0"
- "/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0"
If logs where generated please post these here using code fences:
2020-02-10 14:16:31.189 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node4' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-10 14:16:31.196 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-10 14:16:31.200 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-02-10 14:16:31.203 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node3' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-10 14:16:31.207 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node12' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-10 14:16:31.218 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node11' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-10 14:16:31.225 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-10 14:16:31.230 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
==> /mnt/hdd/logs/openhab.log <==
2020-02-10 14:13:27.400 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:13:27.402 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:13:27.398 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:14:12.568 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-habadmin'
2020-02-10 14:15:10.090 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-habadmin'
2020-02-10 14:15:42.774 [INFO ] [veClimateControlScheduleCommandClass] - NODE 6 reported: Override type: NO_OVERRIDE, ScheduleState: [UNUSED]
2020-02-10 14:16:18.163 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-habadmin'
2020-02-10 14:16:21.576 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 7CB03EAA0A01C16A: Starting ZigBee device discovery
2020-02-10 14:16:26.070 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 7CB03EAA0A01C16A: Starting ZigBee device discovery
2020-02-10 14:16:30.961 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
==> /mnt/hdd/logs/events.log <==
2020-02-10 14:16:34.218 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:05000678:7cb03eaa0a01c16a' has been updated.
2020-02-10 14:16:36.104 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-10 14:16:36.106 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-10 14:16:53.844 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:16:53.848 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:16:53.848 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:16:53.854 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 0002:0005:0004::1.1
2020-02-10 14:16:53.935 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f03965e4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:53.945 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:53.953 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node13' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:53.981 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node7' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:53.997 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node9' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:53.999 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node8' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.002 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f03965e4' has been updated.
2020-02-10 14:16:54.003 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node5' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-02-10 14:16:54.015 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node13' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-02-10 14:16:54.074 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node8' changed from ONLINE to ONLINE: Node initialising: PING
2020-02-10 14:16:54.105 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node9' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-02-10 14:16:54.125 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node15' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.129 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.134 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node12' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.143 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.149 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.152 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node11' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.154 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node14' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.157 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node6' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-10 14:16:54.159 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node8' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2020-02-10 14:16:54.691 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node9' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2020-02-10 14:16:54.741 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node8' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2020-02-10 14:17:12.443 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node13' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-02-10 14:17:12.510 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node13' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.513 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node8' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.561 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.563 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node9' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.611 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node9' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.613 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node7' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.646 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node7' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.651 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node5' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-02-10 14:17:12.684 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node5' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.686 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node14' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.732 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node14' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.734 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node15' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.775 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node15' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.777 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node11' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.811 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node11' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.813 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node12' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.843 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node12' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.845 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node3' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.877 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.879 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node2' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.907 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.909 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node4' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.944 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.946 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node6' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:12.975 [hingStatusInfoChangedEvent] - 'zwave:device:f03965e4:node6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:12.976 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f03965e4' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:13.283 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f03965e4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:17.627 [hingStatusInfoChangedEvent] - 'zigbee:device:05000678:7cb03eaa0a01c16a' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:17.646 [hingStatusInfoChangedEvent] - 'zigbee:device:05000678:7cb03eaa0a01c16a' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:17.948 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_telegesis:05000678' changed from ONLINE to UNINITIALIZED
2020-02-10 14:17:17.949 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_telegesis:05000678' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-10 14:17:18.325 [hingStatusInfoChangedEvent] - 'zigbee:device:05000678:7cb03eaa0a01c16a' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-02-10 14:17:20.278 [me.event.ThingUpdatedEvent] - Thing 'zigbee:coordinator_telegesis:05000678' has been updated.
2020-02-10 14:17:20.351 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_telegesis:05000678' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-02-10 14:17:20.376 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_telegesis:05000678' changed from INITIALIZING to UNKNOWN
2020-02-10 14:17:20.396 [hingStatusInfoChangedEvent] - 'zigbee:device:05000678:7cb03eaa0a01c16a' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-02-10 14:17:20.413 [hingStatusInfoChangedEvent] - 'zigbee:device:05000678:7cb03eaa0a01c16a' changed from INITIALIZING to UNKNOWN
You likely have an invalid addon listed in addons.config in the userdata folder. The loader then restarts all addons every minute trying to load the invalid one.
One common culprit is restdocs since it moved from misc to ui. Stop OH before editing addons.config since it is usually maintained by OH.
Also, please use code fences.
How to use code fences - Tutorials & Examples - openHAB Community
fronti90
(Michael)
February 10, 2020, 1:32pm
3
Thanks for your quick feedback! Fixed the code fences, there was something messed up with the formatting, hope it’s readable like this.
I don’t think there is any invalid config for my addons, here is my textual configuration (/opt/openhab/conf/services/addons.cfg):
binding = astro,homematic,zwave,zigbee,ntp,mqtt,fritzboxtr0641
ui = basic,paper,habadmin
persistence = mapdb,influxdb
transformation = map
misc = openhabcloud
And this is the one in userdata (/opt/openhab/userdata/config/org/openhab/addons.config):
:org.apache.felix.configadmin.revision:=L"10"
binding="astro,homematic,zwave,zigbee,ntp,mqtt,fritzboxtr0641"
misc="openhabcloud"
package="minimal"
persistence="mapdb,influxdb"
service.pid="org.openhab.addons"
transformation="map"
ui="basic,paper,habadmin"
I am getting a bunch of errors about habadmin though, any way to debug this further?
Is the ui habmin or habadmin? Do you have a typo?
fronti90
(Michael)
February 10, 2020, 1:44pm
5
It’s “habadmin” in openhab/conf and openhab/userdata. Which one is correct?
habmin that is likely your issue.
fronti90
(Michael)
February 10, 2020, 1:55pm
7
Thank you both Danny and Bruce, changed it to “habmin”. Seems a lot more stable now.
I’ll keep an eye on the OutOfMemory errors for the next few days.
Good job Danny and Bruce, 35 minutes to a solution, nobody can say this community is not responsive and quick with help for new users!
mhilbush
(Mark)
February 10, 2020, 2:01pm
9
I expect fixing the incorrectly named addon will fix the OOM issue.
https://github.com/openhab/openhab-core/issues/286
Since Kai indicated this as an issue, any ideas why it has not yet been addressed? 2 years is a long time for an issue like this. I guess OH is supposedly stable but not robust??
mhilbush
(Mark)
February 10, 2020, 2:13pm
11
I suspect the leak might be in Karaf feature installer, or in the way OH is using the feature installer. I looked at it a bit, but quickly got in way over my head once my troubleshooting took me inside the Karaf feature installer.
Besides, other than this most recent release, which moved a few bundles around, the problem didn’t happen very often.
Karaf was updated late in the Milestone cycle too.
mhilbush
(Mark)
February 10, 2020, 2:38pm
13
Yeah, I usually check to see if the problem is fixed after every Karaf update. One day maybe I’ll have some time to determine where the leak is coming from so I can open a bug report containing more detail…
