hello @ all
i try to operate my new shelly one by openhab2. I updated openhab to 2.4, installed the mqtt binding and set up a broker this way:
I added a chanel and the shelly one can be switched via the paper ui.
I read a lot posts and discussions, but found only examples with broker set ups via things file. I’m completely confused about creating a item.
I would be happy if any one can tell me how to define the item.
this is what i tried until now:
Switch Shelly_ONE_Kueche { mqtt=">[broker:shellies/shelly1-XXXXXX/relay/0/command:command:*:MAP(shelly.map)],<[broker:shellies/shelly1-XXXXXX/relay/0:state:MAP(shelly.map)]" }
-> did not work also with different map files and installed map transformation
Switch Shelly_ONE_Kueche { channel=“mqtt:topic:be63cb29:Shelly_Kueche:switch” }
-> likewise a failure
Thank you for your fast reply.
It works. Just the “switch” was to much. Didn’t expect that’s easy like this. Please can you also explaine what this code does? [quote=“rlkoshak, post:2, topic:68258”]
<light>
[/quote]
