[SOLVED] Item http binding
Hi, i have a problem with my sitemap and http binding!
On the first image is the value of temperature i want openhab to display on the sitemap, and on the second image is the displayed value on the sitemap..and i want to ask why is this comma appear on it instead of the dot?
Item
Number HTTPstring1 "HTTP [%.2f °C]" { http="<[http://127.0.0.1/openhab.html:1000:REGEX((.*))]" }
First
original
Second
temp2
Thanks!
You need to change your locale:
In openHAB:
PaperUI → Configuration → System → Regional Settings → Country/Region
If that doesn’t work you need to do that at OS level.
And that depends of your OS. What are you running?
Tried it with openhab and nothing…so i suppose i must go to OS level as you told me
Windows 10
Can’t help you there, I haven’t been near windows for 3+ years
https://www.makeuseof.com/tag/change-default-language-region-windows-10/
or
Done! Thanks a lot!
