[SOLVED] Item refreshes state very quickly
Dear Everyone!
I have wondering why this happens… I have some rules which controls RGB leds during the day… However when one of these rules seems active, it refreshes the state really quickly, as I see it in events.log
2018-07-31 23:38:16.964 [ome.event.ItemCommandEvent] - Item 'wifiled2_power' received command OFF
2018-07-31 23:38:16.974 [ome.event.ItemCommandEvent] - Item 'wifiled1_power' received command ON
2018-07-31 23:38:16.981 [ome.event.ItemCommandEvent] - Item 'wifiled_livingroom' received command OFF
2018-07-31 23:38:17.002 [ome.event.ItemCommandEvent] - Item 'wifiled2_power' received command OFF
2018-07-31 23:38:17.012 [ome.event.ItemCommandEvent] - Item 'wifiled1_power' received command ON
2018-07-31 23:38:17.018 [ome.event.ItemCommandEvent] - Item 'wifiled_livingroom' received command OFF
2018-07-31 23:38:17.103 [ome.event.ItemCommandEvent] - Item 'wifiled2_power' received command OFF
2018-07-31 23:38:17.107 [ome.event.ItemCommandEvent] - Item 'wifiled1_power' received command ON
2018-07-31 23:38:17.124 [ome.event.ItemCommandEvent] - Item 'wifiled_livingroom' received command OFF
2018-07-31 23:38:17.272 [ome.event.ItemCommandEvent] - Item 'wifiled2_power' received command OFF
2018-07-31 23:38:17.322 [ome.event.ItemCommandEvent] - Item 'wifiled1_power' received command ON
2018-07-31 23:38:17.359 [ome.event.ItemCommandEvent] - Item 'wifiled_livingroom' received command OFF
In milliseconds… However nothing changes, so it resends the same command these many times… Maybe it’s because that it is unclear for me when these rules fire. I usually use received update, but that’s why it this happens? Maybe using Item … changed is a better approach?
Thanks!
It will be really hard to guess what is going on without the Rules.
Here are my rules related to this:
rule "Night Light in Kitchen and Living Room"
	Item Zone4 changed
	if(Zone4.state.toString == "ON" && (vTimeOfDay.state == "BED" || vTimeOfDay.state == "NIGHT") && CurrentActivityHub.state.toString == "PowerOff" && Sonoff.state.toString == "OFF") {
		// LED on -- Reset timer or start it, if it was turned on before...
		if(gKitchenLedLight.state.toString == "ON") {
			Turn_Off_Leds.sendCommand(ON)
			logInfo("wifiled.rules", "Reset timer")
		// Turn everything on
		else {
			gKitchenLedLight.sendCommand(ON)
			wifiled_livingroom.sendCommand(ON)
			logInfo("wifiled.rules", "Turning on the LEDs...")
rule "Movie/TV Light Kitchen and Living Room"
	Item CurrentActivityHub received update or
	Item Sonoff received update or
	Item gKitchenLedLight received update or
	Item vTimeOfDay changed
	if(Sonoff.state.toString == "OFF" && CurrentActivityHub.state.toString == "Watch a Movie") {
		wifiled2_power.sendCommand(OFF)
		wifiled1_power.sendCommand(ON)
		wifiled_livingroom.sendCommand(OFF)
	else if(CurrentActivityHub.state.toString == "Watch TV" && (vTimeOfDay.state == "EVENING" || vTimeOfDay.state == "NIGHT" || vTimeOfDay.state == "BED")) {
rule "Led Off Timer expired"
	Item Turn_Off_Leds received command OFF
	gKitchenLedLight.sendCommand(OFF)
rule "Turn LED on when Kitchen Light is on"
	if(Sonoff.state.toString == "ON") {
				logInfo("wifiled.rules", "Kitchen LED is turned on manually!")
				Wifiled_Manual.sendCommand(ON)
	else {
		if(Wifiled_Manual.state.toString == "OFF") {
rule "Reset Sonoff_Manual if LED turned off"
	if(gKitchenLedLight.state.toString == "OFF") {
		Wifiled_Manual.sendCommand(OFF)
rule "WifiLed Presets"
	Item wifiled_presets received command
	switch(receivedCommand) {
		case "1" : {
			wifiled1_color.sendCommand("0,100,100")
			wifiled2_color.sendCommand("0,100,100")
rule "Reset Preset button"
	if(gKitchenLedLight.state == OFF) {
		wifiled_presets.postUpdate("")
Also now I got an error like this in VS Code… haven’t changed anything:
[Error - 8:38:31 PM] Request textDocument/definition failed.
  Message: Internal error, please look at the server's logs.
  Code: -32603
[Error - 8:38:44 PM] Request textDocument/definition failed.
  Code: -32603
Maybe you should also post your .items file
It seems that you have an infinite loop…
Example :
I suppose that this zone4 is a group attached to almost all you item in you kitchen.
So, when “Night Light in Kitchen and Living Room” starts, it turns ON/OFF your items.
This raise the group to receive an update. So “Night Light in Kitchen and Living Room” starts again, and again, …
Those errors indicate that VSCode has lost its connection to the language server protocol on OH. Just restart VSCode and the error should clear itself out.
Thanks!
Now it seems that a restart to openHab solved the original issue as well…
Ps.: Not really, I have found it where it loops. But I don’t know why…
This is the line which is executed every 3-5th second, but I don’t know what triggers this every time… Is there a way to find this?
Track what event is triggering the Rule. It may not be that line but some event is occurring over and over and it is just because of the state of everything causes this else to execute.
Forgot to answer, thanks for the help it was just an infinite loop made by me :slight_smile:
It was hard to see first because I have triggered a group, but later in the rule I have sent commands directly to some of the group members…
