But simultaneously I get endless Item ‘Xiaomi_Brightness’ received command 0 log in my openhab and the gateway start to flicker (change its brightness from 0 to 20). I don’t know why I get command 0 ! Where does this command come ?
This is because of the configuration of your binding
Let me explain what happens.
When the binding receives a command it sends a brightnexx command to the gateway with the Xiaomi binding
It also sends the value via MQTT with the second binding
The third binding reacts on a value received and sends a command, which starts the cycle again
In the mean time the Xiaomi binding has replied with it’s state (which was 0)
So your binding start again send, receive, send received…
I am going to ask the same question as in your other thread. What is the purpose on the MQTT binding?
