I have been using Eclipse to start work on a binding which will be making use of Jsoup.
I have created a lib directory in the project where I placed the jsoup-1.11.2.jar file and have added it to the build path under Libraries, Add JARs.
on my Discovery.java I have an import org.jsoup.Jsoup; which the ide is happy with (doesn’t throw an error that it can’t find the class etc.
Although when I try and test I get the following exception thrown:
2018-01-04 19:40:31.252 [WARN ] [e.jetty.servlet.ServletHandler:624 ] - javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/jsoup/Jsoup
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489)
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1223)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:148)
at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:62)
at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:131)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:74)
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/jsoup/Jsoup
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278)
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260)
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509)
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)
Caused by: java.lang.NoClassDefFoundError: org/jsoup/Jsoup
at org.openhab.binding.kevoplus.internal.discovery.KevoLockDiscovery$login.status(KevoLockDiscovery.java:40)
at org.openhab.binding.kevoplus.internal.discovery.KevoLockDiscovery.startScan(KevoLockDiscovery.java:77)
at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:222)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:409)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:394)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:241)
at org.eclipse.smarthome.io.rest.core.internal.discovery.DiscoveryResource.scan(DiscoveryResource.java:97)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
After tearing my hair out going around in circles through google searches I have decided it is time to throw it out to the brains trust and hope someone can help me out with where I am going wrong.
