I moved my openhab2 to another server. The old and the new are both Debian 9 with MariaDB. I installed MariaDB and openhab 2.4 via apt-get on the new server. Imported a sql dump, and restored the openhab backup with the openhab-cli tool. But now I’m getting a lot of errors like this. I have no clue what that is or how to fix.
19:49:19.448 [INFO ] [.persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
19:49:19.912 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.core.persistence.internal.QueryablePersisten
ceServiceDelegate@4f2f5309': java.lang.String cannot be cast to java.lang.Number
java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Number
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.getState(JdbcBaseDAO.java:474) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:343) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:154) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:201) ~[?:?]
at org.openhab.core.persistence.internal.QueryablePersistenceServiceDelegate.query(QueryablePersistenceServiceDelegate.java:47) ~[?:?]
at sun.reflect.GeneratedMethodAccessor56.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
19:49:19.953 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': java.lang.String cannot be cast to java.lang.Number
19:49:19.989 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.core.persistence.internal.QueryablePersisten
19:49:20.018 [ERROR] [tence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': java.lang.String cannot be cast to java.lang.Number
And sometimes
19:55:20.435 [WARN ] [tence.internal.PersistenceManagerImpl] - Failed to delete cron job for persistence service 'jdbc'
19:55:20.712 [INFO ] [.persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
And sometimes there are ‘too many connections’ errors.
There are some other issues which may relate to this.
- marytts produces only silence (no errors in log, worked perfect on the old server)
- Since the upgrade from 2.3 to 2.4 (on the old server) a lot of Homematic items dosn’t have a unit anymore
I have already tried to reinstall the bindings
