[Solved] JDBC MariaDB Table doesn't exists
i have one problem with my persistence setup of my openhab instance.
I get lot of errors regarding not existing table
like
2020-09-07 12:41:43.555 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.core.persistence.internal.QueryablePersistenceServiceDelegate@16054f6': null
2020-09-07 12:41:43.562 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': null
2020-09-07 12:41:43.574 [ERROR] [org.knowm.yank.Yank                 ] - Error in SQL query!!!
java.sql.SQLException: Error preparing query: Table 'openhabian.item0160' doesn't exist Query: SELECT time, value FROM item0160 ORDER BY time DESC  LIMIT 0,1 Parameters: []
or
java.sql.SQLException: Error preparing query: Table 'openhabian.item0160' doesn't exist Query: INSERT INTO item0160 (TIME, VALUE) VALUES( NOW(3), ? ) ON DUPLICATE KEY UPDATE VALUE= ? Parameters: [Finished, Finished]
here is my jdbc.cfg
url=jdbc:mariadb://localhost:3306/openhabian
user=?
password=?
sqltype.STRING        =   VARCHAR(65500)
Strategies {
   everyMinute	: "0 * * * * ?"
   everyHour    : "0 0 * * * ?"
   everyDay     : "0 0 0 * * ?"
   default = everyChange
Items {
 *: strategy = everyDay, restoreOnStartup
HarmonyHubWohnzimmerautomatizationStatus : strategy = everyChange, everyMinute, restoreOnStartup
.items
String	HarmonyHubWohnzimmerautomatizationStatus	"Harmonyautomatization in Status [%s]"
sitemap
Switch item=HarmonyHubWohnzimmerautomatizationStatus label="Harmonyautomatization Status" mappings=[ Started="Started", Finished="Finished"]
I have a lot of table which were not created but i can’t find any error. SO your help is appreciated
Please check if the length of VARCHAR is still limited.
See Jdbc mariadb problem persisting string items
still same error…Nothing changed…
Can I create the tables by myself???
Full instructions how to setup MariaDB
Solved by
