Hi all,. I’am trying to write a rule to sort out my temp sensor in my home and push these values to an Item.
But i’m getting an error in the JSONPATH expression that it can’t execute the filter.
I start with these json strings
MQTT_SENSOR is the incomming json data
jsonLiveSensors is a harcode json string with information about the Sensors that are in the Items.
MQTT_SENSOR== '{"Time":"2017-10-03T21:29:18", "DS18x20":{"DS1":{"Type":"DS18B20", "Address":"28FF4CBFA41604C4", "Temperature":25.44}, "DS2":{"Type":"DS18B20", "Address":"28FF1E7FA116035D", "Temperature":30.37}, "DS3":{"Type":"DS18B20", "Address":"28FF1597A41604CE", "Temperature":23.25}}, "DHT22":{"Temperature":33.20, "Humidity":28.40}, "TempUnit":"C"}'
var String jsonLiveSensors = ' {"DS18x20":[ {"Address":"28FF4CBFA41604C4","Type":"DS18x20","Correction":0,"Name":"PC_kast_temp1","subject":"Temperatuur bovenin midden"}, {"Address":"28FF1E7FA116035D","Type":"DS18x20","Correction":0,"Name":"PC_kast_temp2","subject":"Temperatuur bovenop achter"},{"Address":"28FF1597A41604CE","Type":"DS18x20","Correction":0,"Name":"PC_kast_temp3","subject":"Temperatuur voorin midden"}]}'
and this is the rules part.
var String rData = MQTT_SENSOR.state.toString //Recieved Data
var String rSensors = transform("JSONPATH", "$.DS18x20..Address", rData) // Recieved Sensors Addresses
var rSensorsArr = rSensors.substring(1,rSensors.indexOf(']')).split(",")
for (String i: rSensorsArr) {
if (jsonLiveSensors.indexOf(i)>0 ){ //Check if ID is active
logInfo("MQTT_SENSOR","Address:" + i + " OKE!")
vName = transform("JSONPATH", "$.DS18x20.[?(@.Address==' + i + ')].Name", jsonLiveSensors)
vName = vName.substring(1,vName.indexOf(']'))
logInfo("MQTT_SENSOR","Variable Name:" + vName)
tVal = transform("JSONPATH", "$.DS18x20..[?(@.Address=='"+i+"')].Temperature", rData)
vVal = new Double(tVal.substring(1,tVal.indexOf(']')))
logInfo("MQTT_SENSOR","Variable Value:" + vVal)
if(gTemperature.members.filter[k|k.name==vName].size > 0){
var vItem = gTemperature.members.filter[k|k.name==vName].head
vItem.sendCommand(vVal);
logInfo("MQTT_SENSOR","SendCommand Update:"+vName)
}else{
logInfo("MQTT_SENSOR","SendCommand Fail:"+vName)
}else{
logInfo("MQTT_SENSOR","Address:" + i + " NOT found")
And when i run this and set the correct karaf debug log setting get these errors:
2017-10-05 00:10:32.835 [DEBUG] [ternal.JSonPathTransformationService] - about to transform '{"Time":"2017-10-04T23:10:31", "DS18x20":{"DS1":{"Type":"DS18B20", "Address":"28FF4CBFA41604C4", "Temperature":24.81}, "DS2":{"Type":"DS18B20", "Address":"28FF1E7FA116035D", "Temperature":29.94}, "DS3":{"Type":"DS18B20", "Address":"28FF1597A41604CE", "Temperature":25.31}}, "DHT22":{"Temperature":32.70, "Humidity":29.30}, "TempUnit":"C"}' by the function '$.DS18x20..Address'
2017-10-05 00:10:32.838 [DEBUG] [ternal.JSonPathTransformationService] - transformation resulted in '["28FF4CBFA41604C4","28FF1E7FA116035D","28FF1597A41604CE"]'
2017-10-05 00:10:32.845 [INFO ] [e.smarthome.model.script.MQTT_SENSOR] - Address:"28FF4CBFA41604C4" OKE!
2017-10-05 00:10:32.870 [DEBUG] [ternal.JSonPathTransformationService] - about to transform '{"DS18x20":[
]}' by the function '$.DS18x20.[?(@.Address=="28FF4CBFA41604C4")].Name'
2017-10-05 00:10:32.901 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': An error occurred while transforming JSON expression.
2017-10-05 00:10:32.905 [INFO ] [e.smarthome.model.script.MQTT_SENSOR] - Variable Name:"DS18x20":[
I have tracked the problem to the "+ i + " this translates into double quoted String “28FF4CBFA41604C4” and this doesn’t work with the JSONPATH transform. But i can’t find a way to parse the i-variable as an single quotes String ‘28FF4CBFA41604C4’ then the JSONPATH expression filter works fine.
Does anyone have an idea or workaround of this?
Is this a bug in the transform binding or in the JSONPATH github project itself?
When checking the syntax of the json filter with https://jsonpath.curiousconcept.com/ single or double quotes have the same result but not in Openhab 2.1
