I’m trying to parse the returned JSON from my thermostat to get different values into items, but for now I’m struggling with getting even one value.
I’m retrieving the ATAG One JSON output with an EXEC using a jar I found somewhere around this forum. It has a lot of key value pairs, so for debugging purposes, I removed a whole lot of them, and tried with a static string:
val testVal=" { \"burningHours\": 2216.91, \"roomTemperature\": 21.5 }"
val newValue = transform("JSONPATH", "$.roomTemperature", testVal)
logInfo("Atag","\r\n" + newValue)
regardless of the expression I put in as second parameter in the transform function (as long as its between quotes), it will always return the full string.
When I try the same JSON path $.roomTemperature in the Jayway JsonPath Evaluator, it evaluates fine.
What am I not seeing here? I’m running openhab 2.3 with OpenHabian on a Raspberry Pi 0 W.
Actually the behaviour of returning the whole JSON input document rather than only the parsed sub string is not only happening if the binding is not installed but also if the JSON string in the argument is not correct.
