Hi there!
Im totally noob with OpenHAB2 for the first time, with a clean Debian 8.6 installation at local SoHo LAN, following all the apt-get Linux Instructions for offline snapshot installation, and karaf is apparently not opening any ports to “listen” (nmap tested).
The debug window is not showing apparently any error either.
Here’s the ./start-debug.sh output:
Launching the openHAB runtime...
Listening for transport dt_socket at address: 5005
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.0.0-SNAPSHOT
Build #587
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> log:tail
18:47:24.429 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
18:47:24.793 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
18:47:25.058 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
18:47:25.311 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
All ownership of OpenHAB subdirectories have been checked for openhab:openhab permissions.
And last but not least, htop report’s me lot’s of this parent process:
root 16319 1.8 23.2 2842952 238004 pts/0 Sl+ 18:47 0:46 /usr/lib/jvm/java-8-oracle/bin/java -agentlib:jdwp=transport=dt_socket,server=y,suspend=n,address=5005 -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openha
Thanks for this great project. Im exciting to look it working on!
