Platform information:
Hardware: RPi 4 8 GB and 32 GB micro SD + zwave: Aeotec Z-Stick Gen5 (ZW090) - UZB
OS: Raspian which comes with openhabian 1.6 beta
Java Runtime Environment: Zulu 8 (standard openhabian)
openHAB version: 2.5.10-1 (standard openhabian)
All,
I am running zwave successfully several years.
Recently I replaced a sensative strip due to battery failure with a Fibaro FGDW002.
The first inclusion did not finish properly (device not recognized as fibaro FGDW).
A second try was better and the device is online.
However, I do neither get a change OPEN / CLOSED nor a Battery update.
The main (frequent) change I see (log is on TRACE level):
2020-12-08 16:05:54.897 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 18: listening == false, frequentlyListening == false, aw$
2020-12-08 16:05:54.898 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 18: Node not awake!
Furthernmore this happened after new include process:
2020-12-08 15:17:43.690 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 18: Message payload = 00 12 05 8E 03 03 05 00
2020-12-08 15:17:43.690 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2020-12-08 15:17:43.690 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: TID 960: Transaction not completed
2020-12-08 15:17:43.691 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-12-08 15:17:43.691 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2020-12-08 15:17:43.691 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-12-08 15:17:43.692 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=18, callback=0, payload=00 12 05 8E 03 03 05 00
2020-12-08 15:17:43.692 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2020-12-08 15:17:43.692 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2020-12-08 15:17:43.693 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Dec 08 15:17:48 CET 2020 - 4997ms
2020-12-08 15:17:43.694 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=18, callback=0, payload=00 12 05 8E 03 03 05 00
2020-12-08 15:17:43.694 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-12-08 15:17:43.695 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: Application Command Request (ALIVE:STATIC_VALUES)
2020-12-08 15:17:43.696 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 18: Incoming command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0
2020-12-08 15:17:43.696 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 18: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2020-12-08 15:17:43.697 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 18: Received COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION V3 MULTI_ASSOCIATIONCMD_REPORT
2020-12-08 15:17:43.697 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 18: association group 3 has max associations 5
2020-12-08 15:17:43.698 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAssociationEvent
2020-12-08 15:17:43.698 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveAssociationEvent
2020-12-08 15:17:43.699 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ASSOCIATION, value=0
2020-12-08 15:17:43.700 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Checking channel=zwave:device:12345678-9012-3456-7890-123456789012:node18:sensor_temperature, cmdClass=COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint=0
2020-12-08 15:17:43.700 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Checking channel=zwave:device:12345678-9012-3456-7890-123456789012:node18:alarm_tamper, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
2020-12-08 15:17:43.701 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Checking channel=zwave:device:12345678-9012-3456-7890-123456789012:node18:sensor_door, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
2020-12-08 15:17:43.701 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Checking channel=zwave:device:12345678-9012-3456-7890-123456789012:node18:alarm_power, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
2020-12-08 15:17:43.702 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Checking channel=zwave:device:12345678-9012-3456-7890-123456789012:node18:alarm_heat, cmdClass=COMMAND_CLASS_ALARM, endpoint=0
2020-12-08 15:17:43.703 [TRACE] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Checking channel=zwave:device:12345678-9012-3456-7890-123456789012:node18:battery-level, cmdClass=COMMAND_CLASS_BATTERY, endpoint=0
2020-12-08 15:17:43.703 [DEBUG] [ss.ZWaveMultiAssociationCommandClass] - NODE 18: All association groups acquired.
2020-12-08 15:17:43.704 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNetworkEvent
2020-12-08 15:17:43.704 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveNetworkEvent
2020-12-08 15:17:43.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: Commands processed 1.
2020-12-08 15:17:43.705 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1a1051e.
2020-12-08 15:17:43.706 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 18: Checking transaction 960 ApplicationCommandHandler.
2020-12-08 15:17:43.706 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 18: Checking transaction : state >> WAIT_DATA
2020-12-08 15:17:43.707 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 18: Checking transaction : node >> 18
2020-12-08 15:17:43.707 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 18: Checking transaction : class >> 142 == 142.
2020-12-08 15:17:43.708 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 18: Checking transaction : commd >> 3 == 3.
2020-12-08 15:17:43.708 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1a1051e.
2020-12-08 15:17:43.709 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 960: TransactionAdvance ST: WAIT_DATA
2020-12-08 15:17:43.709 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 960: TransactionAdvance WT: ApplicationCommandHandler {}
2020-12-08 15:17:43.710 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 960: TransactionAdvance RX: Message: class=ApplicationCommandHandler[4], type=Request[0], dest=18, callback=0, payload=00 12 05 8E 03 03 05 00
2020-12-08 15:17:43.710 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 960: TransactionAdvance TO: DONE
2020-12-08 15:17:43.711 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: notifyTransactionResponse TID:960 DONE
2020-12-08 15:17:43.712 [TRACE] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2020-12-08 15:17:43.712 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-12-08 15:17:43.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2020-12-08 15:17:43.713 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-12-08 15:17:43.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-12-08 15:17:43.714 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-12-08 15:17:43.715 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 11: listening == false, frequentlyListening == false, awake == false
2020-12-08 15:17:43.715 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 11: Node not awake!
2020-12-08 15:17:43.716 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: listening == false, frequentlyListening == false, awake == false
2020-12-08 15:17:43.716 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 8: Node not awake!
2020-12-08 15:17:43.717 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 15: listening == false, frequentlyListening == false, awake == false
2020-12-08 15:17:43.717 [TRACE] [nal.protocol.ZWaveTransactionManager] - NODE 15: Node not awake!
2020-12-08 15:17:43.721 [TRACE] [ng.zwave.internal.protocol.ZWaveNode] - NODE 18: listening == false, frequentlyListening == false, awake == true
2020-12-08 15:17:43.721 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
2020-12-08 15:17:43.722 [TRACE] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2020-12-08 15:17:43.722 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 18: Creating empty message of class = SendData (0x13), type = Request
2020-12-08 15:17:43.723 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = 0
2020-12-08 15:17:43.724 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 12 02 5E 01 25 8F 00
2020-12-08 15:17:43.726 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 18: Sending REQUEST Message = 01 09 00 13 12 02 5E 01 25 8F 00
2020-12-08 15:17:43.729 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-12-08 15:17:43.730 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 961: Transaction Start type SendData
2020-12-08 15:17:43.730 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-12-08 15:17:43.730 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 961: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2020-12-08 15:17:43.731 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 06
2020-12-08 15:17:43.731 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: COMMAND_CLASS_ZWAVEPLUS_INFO
2020-12-08 15:17:43.732 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 2
2020-12-08 15:17:43.732 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-12-08 15:17:43.732 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2020-12-08 15:17:43.733 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2020-12-08 15:17:43.734 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Dec 08 15:17:45 CET 2020 - 1999ms
2020-12-08 15:17:43.735 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 961: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2020-12-08 15:17:43.735 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2020-12-08 15:17:43.736 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Dec 08 15:17:45 CET 2020 - 1998ms
2020-12-08 15:17:43.736 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2020-12-08 15:17:43.736 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-12-08 15:17:43.737 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 961: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2020-12-08 15:17:43.737 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-12-08 15:17:43.737 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-12-08 15:17:43.738 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-12-08 15:17:43.739 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-12-08 15:17:43.739 [TRACE] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2020-12-08 15:17:43.740 [TRACE] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2020-12-08 15:17:43.740 [TRACE] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Tue Dec 08 15:17:45 CET 2020 - 1993ms
2020-12-08 15:17:43.738 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 04 01 13 01 E8
2020-12-08 15:17:43.742 [TRACE] [wave.internal.protocol.SerialMessage] - Calculated checksum = -24
2020-12-08 15:17:43.743 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
2020-12-08 15:17:43.744 [TRACE] [wave.internal.protocol.SerialMessage] - NODE 255: Message payload = 01
2020-12-08 15:17:43.745 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
2020-12-08 15:17:43.747 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2020-12-08 15:17:43.748 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-12-08 15:17:43.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-12-08 15:17:43.750 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 961: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2020-12-08 15:17:43.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-12-08 15:17:43.752 [TRACE] [WaveSerialHandler$ZWaveReceiveThread] - Received SOF
2020-12-08 15:17:43.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 961: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 143
2020-12-08 15:17:43.753 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-12-08 15:17:43.754 [TRACE] [ve.internal.protocol.ZWaveController] - Incoming Message type = RESPONSE
2020-12-08 15:17:43.754 [TRACE] [l.serialmessage.SendDataMessageClass] - Handle Message Send Data Response
2020-12-08 15:17:43.755 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 18: sentData successfully placed on stack.
2020-12-08 15:17:43.755 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 961: TransactionAdvance ST: WAIT_RESPONSE
2020-12-08 15:17:43.756 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 961: TransactionAdvance WT: ApplicationCommandHandler {}
2020-12-08 15:17:43.755 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 8F 00 00 02 66
2020-12-08 15:17:43.756 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 961: TransactionAdvance RX: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-12-08 15:17:43.757 [TRACE] [e.internal.protocol.ZWaveTransaction] - TID 961: TransactionAdvance TO: WAIT_REQUEST
2020-12-08 15:17:43.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 961: Advanced to WAIT_REQUEST
2020-12-08 15:17:43.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 18: TID 961: Transaction not completed
Any idea what this means?
@chris log viewer is not available:
https://www.cd-jackson.com/index.php/openhab/zwave-log-viewer
