Hi i’m new to OPENHAB and trying to find some info about the KMTronic 8 Relays configuration.
Is there somebody who’s using this with OpenHab2 ?
I’t a wired unit with 8 relays wich connect via LAN
Here’s more info:
NOTE:
UDP Relay board is developed for software control.
For control via Web Browser - Windows Explorer, Mozilla, Google Chrome… we recommend WEB version.
A general purpose LAN Relay controller.
Features:
• Fully assembled and tested.
• Each relay has an LED to indicate when it is operated.
• Relay outputs can be used to turn ON/OFF lights, motors and other devices.
Model:
UD8CR
Complete including:
- One LAN Eight relay controller
Required power:
12VDC / 1000 mA.
Specifications:
Relays have Normally Open (NO) and
Normally Closed (NC) Contacts each capable of switching max:
- 12VDC/15A
- 24VDC/15A
- 125VAC/15A
- 250VAC/10A
Dimensions:
KMTronic_8Relay_Dimension.pdf
Default Settings:
IP address: 192.168.1.199
Webserver Port: 80 (for initial configuration with username/password)
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
UDP Port: 12345
Username: admin
Password: admin
Reset to Default Settings:
Hold Reset button for 10 seconds
UDP Commands:
FF0000 - Status Read command (ASCII encoding)
FF0100 - Relay 1 OFF command (ASCII encoding)
FF0101 - Relay 1 ON command (ASCII encoding)
FF0200 - Relay 2 OFF command (ASCII encoding)
FF0201 - Relay 2 ON command (ASCII encoding)
FF0800 - Relay 8 OFF command (ASCII encoding)
FF0801 - Relay 8 ON command (ASCII encoding)
FFE000 - All relays OFF command (ASCII encoding)
FFE0FF - All relays ON command (ASCII encoding)
UDP Test Software example including source code (C#):
