Hi All,
Hopefully someone can help with a little problem I’m having with a KNX energy meter.
The energy meter sends the correct readings to the EIB/BUS but the readings read by openHab are incorrect.
OpenHab Log:-
Group gPower
Number Current_Consumption_Power "Consumption [%.0f W]" <energy> (gPower) {channel="knx:device:d89c6827:3"}
Number Voltage "Voltage [%.0f V]" <energy> (gPower) {channel="knx:device:d89c6827:5"}
Number Current "Current [%.0f A]" <energy> (gPower) {channel="knx:device:d89c6827:6"}
KNX energy meter log:-
#,Time,Service,Flags ,Prio,Source Address,Source Name,Destination Address,Destination Name,Rout,Type,DPT,Info
3,04/11/2018 20:31:30.963,from bus,,Low,1.1.4,KES Plus,0/2/4,Voltage,6,GroupValueWrite, 14.027 electric potential (V),43 72 78 52 | 242.47 V
4,04/11/2018 20:31:30.993,from bus,,Low,1.1.4,KES Plus,0/2/5,Current,6,GroupValueWrite, 14.019 electric current (A),40 23 B6 46 | 2.558 A
5,04/11/2018 20:31:31.030,from bus,,Low,1.1.4,KES Plus,0/2/0,Current Consumption,6,GroupValueWrite, 14.056 power (W),43 C7 00 00 | 398 W
OpenHab Log:-
2018-11-04 20:31:52.423 [vent.ItemStateChangedEvent] - Current_Consumption_Power changed from 2475.52 to 2460.16
2018-11-04 20:32:02.383 [vent.ItemStateChangedEvent] - Current changed from 81.92 to 84.48
2018-11-04 20:32:02.418 [vent.ItemStateChangedEvent] - Current_Consumption_Power changed from 2460.16 to 2465.28
2018-11-04 20:32:12.345 [vent.ItemStateChangedEvent] - Voltage changed from 2257.92 to 2255.36
As you can see from the logs the readings are completely different.
Thanks in advance.
