I currently use two main patterns for adjusting light levels:
Adjusting lights that are currently ON based on time of day (Astro is not a good idea in Norway as we have few non-sunny hours in the summer and few sunny hours during the winter).
For some motion triggered lights (for example in the bathroom) I have special rules which, when motion is detected, turns some lights on or not based on time of day and adjusts the light to different levels than those in #1.
What I am missing now is some way of dimming lights which are turned on and are not in the #2-umbrella to (for example) the PresetDimLevel.
Something like:
rule "Some light switched to ON. Set the changed light to correct dimlevel"
when gLight changed
//Figure out which light it was that changed to ON
//Set this light to the correct dimlevel
Is there a common pattern for this which I can re-use?
My âpatternsâ Pattern 1: Adjusting dimlevels for lights that are already on
Items:
Group gDimmer
Number Dimmer1 (gDimmer) {....}
Number Dimmer2 gDimmer) {....}
Number PresetDimLevel
Switch UpdateLightLevels
Rules:
rule "6:30, weekday - night is over, adjust to early morning light"
Time cron "0 30 6 ? * * *"
PresetDimLevel.postUpdate(20)
Thread::sleep(500)
UpdateLightLevels.sendCommand(ON)
rule "React on UpdateLightLevels switch, send target percentage"
Item UpdateLightLevels changed to ON
UpdateLightLevels.postUpdate(OFF)
gDimmer.members.forEach[ item |
if (item.state > 0) {
logInfo("lightingschedule.rules", "Item state: " + item.state)
item.sendCommand(FF_AllLights_PresetPercNormal.state as Number)
Pattern 2: Turning on lights by motion detection
Items:
Contact Bathroom_Motion
Switch Bathroom_Dimmable_Light {....,expire=....}
Bathroom_Small_Lights {...}
Bathroom_Strong_Light {...}
rule "Bathroom_Motion received update"
Item Bathroom_Motion received update
if (Bathroom_Dimmable_Light.state==ON){
Bathroom_Dimmable_Light.postUpdate(ON) //Delay expire
else{
val CurrentHour = now.getHourOfDay
if (CurrentHour > 6 && CurrentHour < 11){
Bathroom_Dimmable_Light.sendCommand(70)
Bathroom_Small_Lights.sendCommand(ON)
else if (CurentHour....)..
Edit: The Solved-post gave the right answer and another post show my actual implementation which includes this solution.
Member of gLight changed
triggeringItem.sendCommand(dimlevel)
In order to make this as general as possible (and in order to be able to turn off lights - which I donât think will be possible with the rule above), one would need to check for something like:
Member of gLight changed from 0
âŠ
But documentation has it that this should work just fine!
Hmmm, it seems like it should have worked and I get the following logged:
â2018-10-25 19:35:26.595 [ome.event.ItemCommandEvent] - Item âFF_Sov2_Light_Dimmerâ received command 20â
So the rule correctly sends the command and I get the âreceived commandâ-event, but not the two âpredicted to becomeâ- and âchanged toâ-events which I get if I use the openhab-console to send the command for example. And the light is not dimmed to 20 as hoped.
rule "Some dimmable light switched to ON. Set the changed light to correct dimlevel"
Member of gDimmer changed from 0
logInfo("Lightningschedule.rules", "The dimmable item " + triggeringItem.name + " turned on. Dim to correct level.")
Thread::sleep(500)
triggeringItem.sendCommand(FF_AllLights_PresetPercNormal.state)
Adding asDecimalType (deprecated) and then transforming into and int is adding to the execution time and adding a lot of time at parsing time.
Try not to use primitives (int, floatsâŠ) unless really necessary
Iâm using the Astro binding for sun-rise/set with location set to Oslo without any issues for over a year now.
What was you problem?
Are you even further north perhaps?
I live in Oslo as well, but using astro sounds like a very bad idea to me. The sunrise July 1st is at like 4AM, too early for all lights to be way bright imo, and now itâs at 8.15 or something which is too late.
If my kids wake up at 5AM to go pee, I want them to feel itâs night and go back to bed, preferably without waking us up, both in the winter and the summer.
So, for regular work days, all lights are dimmed way down until 6 or 6.30 and are way bright from 7 when the day has started. And all lights start dimming slowly down from 7PM onward.
My outdoor lights are astro-timed though and that works well.
