Hi all,
I’m using a rule to turn my water fountain to ON when a motion sensor detected motion three times.
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.java.math.*
import org.joda.time.*
var Number counter = 0
var Number lastCheck = 0
rule "Fountain ON" //when motion is detected 3 times
Item FibEye1_Motion_C changed from CLOSED to OPEN
counter = counter + 1
if(counter>2) {
sendCommand(Licht_UG_Fountain, ON)
ItemFountainCount.postUpdate(counter) //show counter in GUI
rule "Fountain OFF"
Time cron "0 * * * * ?"
if(lastCheck == counter) {
counter = 0
lastCheck = -1;
sendCommand(Licht_UG_Fountain, OFF)
} else {
lastCheck = counter
This works fine since a couple of month.
Now I would like to limit this to a certain time, for example 9AM to 10PM.
So I’ve put around the rule:
if ((now.getHourOfDay() < 22) || (now.getHourOfDay() > 8)) {
if(counter>2) {
rule "Fountain OFF"
counter = 0
lastCheck = -1;
} else {
lastCheck = counter
This doesn’t work at all. The fountain is still doing its job all day. What are I’m doing wrong?
Thanks for any hint.
