When i remove completely openhab2, the localhost:8080 still working, how can i resolve this?
Because i want to install openhab2 again, and choose de Standart configuration.
Did you shut it down?
Also: Are you on Linux or Windows?
If Linux: How did you remove OH2 from your system?
By the way: To change the configuration to something else than the first choice that you made, modify file: conf/services/addons.cfg
and change the package =
to whatever you want. No need to re-install OH2.
Yes, but still not working…
But i found a solution, if i follow this steps is possible to solve the problem, after uninstall openhab2, the localhost:8080 is now offline and when i reinstall OH2 i can choose the standart configuration and works great.
Step 1 - (always on the terminal)
sudo updatedb
[Unknown command error]
sudo apt-get install mlocate
Step 2 - [next]
locate openhab*
[or]
locate openhab*
[or]
locate openhab -> works to me
[or]
locate *openhab*
[After use this commands, will appear a list of files and directories that have openhab in the name]
[Delete all that files and directories on the list]
[Next, repeat all the Steps to check again if appear more files and directories that have OH2 in the name]
[If not, make reboot and verify if localhost:8080 is now offline and install OH2]
Linux, Ubuntu 16.04
To remove OH2, use this command:
sudo apt-get purge openhab2*
or
sudo apt-get remove openhab2*
sudo updatedb
Step 2 - [next]
locate openhab*
[or]
locate openhab*
[or]
[or]
locate *openhab*
