OK, well thats embarrassing, as soon as I posted I managed to solve my own problem (no luck the 2 hours prior of course!) BUT I am leaving it up here in case anyone else has the same problem. Solution for me was to add the line (under the line “Extra arguments passed to Java”)
JAVA_ARGS=-Duser.timezone=America/New_York
in the file:
/etc/default/openhab`
Here is the Wikipedia list of Timezone names: Time Zone Names
Then press Crtl+X to close the file, then press Y for Yes to save the changes, and then press Enter to overwrite the existing file.
After that restart the openHAB service:
sudo systemctl restart openhab2
Or do a system reboot:
sudo reboot
I tried to include as much detail as possible, for those who are as new to this as I am, who might stumble across this post. Honestly, I hate command line based interfaces. But it is what it is…
@martinvw Martin, you are quite knowledgable in docker, do you have any idea how I can EXTRA_JAVA_OPTS value in /etc/default/openhab2 in case of a docker installation as describe by @BigRedBrent ?
I can’t seem to find any openhab2 file in my docker installation
I was also aware of link you shared. The strange thing is all times seem to be correct in the openhab system only the fronttail logging times are 2 hours off.
