[SOLVED] LogitechHarmony Hub Binding not responding anymore
Never mind… it just came back online…
Not sure what changed… but OH2 wasn’t updated… So must have been on the Logitech side.
After flashing the special FW some months ago I didn’t need to enable XMPP this way and worked until 1-2 days ago… but it is working now after enabling:
2019-02-20 17:14:39.679 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:Batcavelivingroom' changed from OFFLINE (COMMUNICATION_ERROR): Could not connect: Failed communicating with Harmony Hub to ONLINE
2019-02-20 17:14:39.687 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Batcavelivingroom:32745628' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-02-20 17:14:39.690 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Batcavelivingroom:32745403' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-02-20 17:14:39.691 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Batcavelivingroom:32741569' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-02-20 17:14:39.692 [hingStatusInfoChangedEvent] - 'harmonyhub:device:Batcavelivingroom:40755671' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2019-02-20 17:14:39.697 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:device:Batcavelivingroom:40755671' has been updated.
2019-02-20 17:14:39.717 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:hub:Batcavelivingroom' has been updated.
2019-02-20 17:14:39.718 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:device:Batcavelivingroom:32745628' has been updated.
2019-02-20 17:14:39.719 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:device:Batcavelivingroom:32745403' has been updated.
2019-02-20 17:14:39.720 [me.event.ThingUpdatedEvent] - Thing 'harmonyhub:device:Batcavelivingroom:32741569' has been updated.
@Dan
Is it running now?
2019-02-20 23:20:12.875 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HQ' changed from OFFLINE (COMMUNICATION_ERROR): Could not connect: java.net.SocketTimeoutException: Connect Timeout to OFFLINE (COMMUNICATION_ERROR): Could not connect: java.net.ConnectException: Verbindungsaufbau abgelehnt
after removing and re-adding thing:
2019-02-20 23:22:11.243 [hingStatusInfoChangedEvent] - 'harmonyhub:hub:HQ' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Could not connect: Could not discover host 192.168.xxx.xxx
Is the IP address correct?
yes! I can get a ping and the harmony app is working…
added the thing with autodetection in paperui
@Dan
  2.5.0.201902041209
seems to be snapshot version manually downloaded from Github and then copied into addons folder. Did you?
yes I tried 2 days ago, after thing stopped working, but then removed the jar after no luck with that… then reinstalled the binding through paperui
I’m on debian stretch
openhab 2.5.0-SNAPSHOT Build #1492
@Dan
It seems to be cache problem.
Goto cache folder then 296 and delete the files there.
Done… restarting OH now
@Dan
Now you have to reinstall the harmony binding again via PaperUI.
After reinstalling:
2019-02-20 23:50:57.729 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-harmonyhub': Error restarting bundles:
        Could not resolve module: org.openhab.binding.harmonyhub [300]
  Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="2.5.0.201902041209"; osgi.identity="org.openhab.binding.harmonyhub"; singleton:="true"
in karaf
298 x Active    x  80 x 2.5.0.201902041209     x HarmonyHub Binding
300 x Installed x  80 x 2.5.0.201901082136     x HarmonyHub Binding
Ok
removed all harmony binding entries in karaf
uninstalled the binding in paperui
reinstalled the binding without restarting OH2
and finally my Harmony Hub is back! thanks a lot!!
Had the same issue that the harmony hub went offline a couple of days ago.
2.4.0 stock binding.
Hub 4.15.250.
Fixed by enabling XMPP, thanks!
I have the harmony hub 4.15.250 software version, and i have the “OFFLINE - COMMUNICATION_ERROR”. How to enable the XMPP?
From the Harmony app,
Hamburger menu → Harmony Setup → Add/Edit Devices & Activities → Remote & Hub
The Enable XMPP option should be at the bottom.
Yes, thanks, worked
Just need to get the right widget for the habpanel
